91 Octane Gas V12
Bottom line: use 91 octane , at least in a V12 and especially if you plan to keep the car for an extended period of time.
Chris
One can abuse a $150K+ car w/various approaches like using cheapest avail fuel; avoiding/delaying rec'd mtce; delaying replacement of worn tires....and putting on cheapest avail non-perf tires, etc etc....but laughably self-defeating frugality when driving a fast-depreciating $150K+ car.....
In an ideal world, wish CA would have easily avail 95 oct fuel, smoothly paved roads and no speed lims on fwys....
But we do have world's cheapest cars and some of world's best weather/topography/mtn twisties around SF and LA to enjoy our cars 365d/yr on summ perf tires/wheels
BTW, Does running 98 octane do harm as much as running low octanes do? If it says run 93 octance on the sticker, can that be interpreted as 93 or higher?
RON: Research Octane Number.
MON: Motor Octane Number.
AKI: Anti-Knock Index. ((RON+MON)/2)
European fuels are measured by RON (ie. "98 RON")
American fuels are measured by AKI (ie "93 octane")
Typical difference in RON:MON is approx. 10 points (although it varies with different brands, qualities), so 98RON/88MON = (98+88)/2 = 93 AKI, so it's the same rating.
My opinion on lower octane gases: the difference between 89 and 91 is 10 cents? 20 cents at most? So say you have a 20 gallon tank @ $3/gallon, you'd be paying a whopping $64 for 91 instead of $60 for 89. IMO the damage that could potentially be done to your engine isn't worth saving that $4 for. On that note, I also only fill up at quality gas stations (chevron, 76, shell) again because I wouldn't want to risk putting in gas with unknown quality to save a couple of bucks in the short run.
On a side note, lower "octane" gas is actually better, because the word "octane" is a misnomer - 87,89,91,93 are anti-knock indexes - 91 is more resistant to burning than 87 and thus the reason for it being less sensitive to detonation.
If your car calls for 87 gas, use 87 gas because 91 will negatively impact performance.
Wow. Great information. Thanks for the knowledge. I used to know that part about RON,MON, and AKI but over the years forgot it. Nice refresh of info.
http://autorepair.about.com/od/generalinfo/a/110305.htm
Z356
