Updated 2010 w221 taillights on older w221
Old 01-11-2011, 11:06 PM
  #326
egauster's Avatar
S550 4matic, ML350
Originally Posted by danodano
Hey Eric,
He is suggesting I try a modification to get it working first. If that doesnt work, Il do that.
Could you do me a favor? Can you tell me how the rear lights are supposed to look during normal operation?
What I mean is, there is 2 modes, I believe:
When you are driving with your lights off, are all 3 rows lit?
When you are driving with your lights on, are all 3 rows lit?
Looking at them, there IS a slight difference. On mine, all rows light up when the brakes are on. The 2010+ OEM units, only the bottom segment, I believe. I like the fact that the retrofits light up more LEDs then OEM...
Other then that they are identical...
Old 01-14-2011, 10:54 AM
  #327
danodano's Avatar
2008 G55
Ok, I just got a new set of lights from fishcake.
New ones work perfect, no errors and everything lights up, all 3 rows.
I have a early 2007 4matic s550
-Dan
Old 01-14-2011, 11:04 AM
  #328
RobertM's Avatar
mercedes 2011 CLS550 with AMG package
-Dan
did you install them yourself ??
If yes; where did you start.
take off . . . .
I have 2 left thumbs
Old 01-14-2011, 02:11 PM
  #329
danodano's Avatar
2008 G55
take off . . . .
Yes I did it myself.
Its about a 30 minute job.
You need to remove the carpeted walls from the left and right sides, inside the trunk- This gives you access to the lights where you can unbolt them and slide new ones in.
Old 01-23-2011, 09:02 PM
  #330
RobertM's Avatar
I started the process and then only got to the removal of the first section where the trunk attaches and then . . . . . . . ok I better put it back together and go my buddies body shop.
Old 01-25-2011, 08:04 PM
  #331
RobertM's Avatar
I had a friend help me and they took 30 minutes or so to install. Plug and Play. they really look fantastic.
I purchased them on ebay from expresspart, and all the lights come on when the brakes are on as well. I like that vs the OEM because it is hard to miss that I am braking !!!
Old 01-26-2011, 09:04 AM
  #332
danodano's Avatar
2008 G55
All 3 rows of mine are always on- When the brakes go on, they just go way brighter. Isnt that how it ssupposed to be? Looks way better imo, if its not :P
Old 01-30-2011, 06:12 PM
  #333
RobertM's Avatar
lights are ONLY on when the lights are on. Just like OEM, the only difference is that when you step on the brake, all the lights come on. Other than that, typical OEM.
did you get your from ExpressPart ???
Old 01-30-2011, 11:07 PM
  #334
danodano's Avatar
2008 G55
I got it from fishcake.
Old 07-10-2011, 01:43 PM
  #335
C-DiZzY's Avatar
2010 S550
I want to order them today but don't know who to order from on e-bay. I know a while back when they first came out you had to modify them with a wire or get a sam. Did they fix it now so all you do is plug and play? And who should i get them from? fishcake or expresspart?
Old 07-10-2011, 02:02 PM
  #336
FJT
FJT's Avatar
2008 S63
I'm still getting an rear right sidemarker lamp and rear left sidemarker lamp. No sure how to fix it. The Sam will not take to programming.
Old 07-10-2011, 10:29 PM
  #337
RobertM's Avatar
I got mine from expresspart and they were plug and play. NO ISSUES !!! The only difference is that when the brake light is on, both rows light up vs the OEM which only the bottom come on. ACTUALLY better if you ask me.
Old 07-13-2011, 10:07 PM
  #338
rmajor's Avatar
2015 S550 4Matic, 2017 C300 4Matic. Retired, 2007 S550, 2014 CLS550 4Matic
Purchased mine from Expressparts also and I am very pleased with the look....
https://mbworld.org/forums/members/r...cs550pic70.jpg
https://mbworld.org/forums/members/r...cs550pic80.jpg
Old 07-13-2011, 10:11 PM
  #339
jadeethan's Avatar
toyota sienna, S550, Subaru Outback
Looks great! No errors i presume?
Thanks!
Old 07-13-2011, 11:29 PM
  #340
rmajor's Avatar
Thanks!
No errors at all, a lot of compliments on the street from the 2010 owners when they see the difference when I apply the brakes.
Old 07-18-2011, 06:07 AM
  #341
FJT
FJT's Avatar
2008 S63
Originally Posted by FJT
I'm still getting an rear right sidemarker lamp error and rear left sidemarker lamp error. No sure how to fix it. The Sam will not take to programming.
Was wondering if anyone can help? Was this the error people were receiving? Mine were original OEM lights.
Thank you
Old 07-18-2011, 10:22 PM
  #342
s550 vellano's Avatar
2007 s550
Originally Posted by rayden33
Just picked up W221, was wondering if anyone but that dealer done this tail light conversion yet? I am thinking of doing it.
is about 1500 usa money done right at dealer
Old 07-23-2011, 10:41 AM
  #343
jprescott's Avatar
ML-350, Maserati Quattroporte
Ok, after following this thread for what seems like forever, it appears that the upgrade has evolved to a simple plug and play for about $500. Finally a cheap solution if we use the expressparts tail light. I am ready to pull the trigger myself but I would love a bit more detail(even photos) from rmajor, robertm and danodano on the install. How do I remove carpet, identify correct bolts and plug in wire?
Old 07-23-2011, 02:17 PM
  #344
rmajor's Avatar
JPrescott,
You can view the finished look thru my photo album, the lights were installed by a recommended MB service and repair (private garage) but I don't have the name or remember the exact street address in North Hollywood.
I have since moved to the east coast. However, the folks over at Expressparts can give you their name.
The install took maybe 25 minutes start to finish, the carpet is simply peeled back and lifted out of the way but not removed, a few plastic moldings have to be removed along the edge of the trunk, paid the guy 75.00 to install both and I paid a few dollars less for the lights than the website has adverstised because as you will see in my photos I installed the smoked lens instead of the clear.
Absolutely no rewiring or reflashing work required, plug and play as stated, and no errors and way less expensive than the OEM for the purists, I understand, but I am good with minor mods and adjustments your dime, your choice.
If you want to discuss in directly PM me and send your contact details.
Rich
Old 07-23-2011, 08:05 PM
  #345
zer0t's Avatar
2017 S550, 2017 C63S, 2019 Raptor
Can someone provide a link to where I can by these assemblies? I have an 08 w221 and would love the led upgrade.
Old 07-23-2011, 08:28 PM
  #346
zer0t's Avatar
Found them from fishcake321.
Old 07-23-2011, 08:32 PM
  #347
zer0t's Avatar
I just saw this.....what was the outcome?
Originally Posted by skkons42
Full View Re: MY EMAIL ADDRESS
Add to ContactsTo:Morris Tate <skkons4@yahoo.com> 7 Files View Slideshow Download All
TL_MBZ_W221_RESISTOR.JPG (167KB); STEP1.JPG (143KB); STEP2_UNPLUG_WHITE_PLUG.JPG (105KB); STEP3_CUTOFF_WHITE_PLUG.JPG (121KB); STEP4_LEFT_SIDE.JPG (127KB); STEP5_PUSH_IN_RESISTOR.JPG (134KB); STEP6_RIGHT_SIDE.JPG (140KB)
#cg_msg_content DIV {MARGIN:0px;}If you or the installer can do it, we will be sending 2 black LED resistor as shown in the photo.
And what needs to be done is show in photos by the step. You have two ways to do it. Soldering or use tap splice.
FIRST WAY - Soldering:
Step 1. what you have received.
Step 2. un-plug the white plastic plug from the tail light
Step 3. cut off the white plastic plug tip and ready to solder to fuse the wires together.
Step 4. LEFT side should have BLACK to WHITE and RED to GRAY, if you solder the wires together and use heat shrink tube to shrink wrap once the soldering is done.
Step 5. Push in the new Black Resistor that we are supplying
Step 6. RIGHT side should have BLACK to GRAY and RED to WHITE, if you solder the wires together and use heat shrink tube to shrink wrap once the soldering is done.
SECOND WAY - Use tap splice, no soldering, this way is easier, but also less secure as sometimes the wires might get loose then it will loose the electrical contact, then lose the connection:
Step 3. Use tap splices to connect as Step 4 and 6 for left and right sides following this simple instruction http://www.speedstersource.com/FISH/INSTALL_AE.htm
Let me know if you have any question, thanks.
Regards,
Simon
Dear fishcake321,
Error message: Tail lamp, brake lamp, right substitute bulb on.
On the left light, only reverse, blinker, and very top bulb (not led) is working. On right light, only reverse and very top bulb (not led) is working. None of the LED for the top or bottom rows are working, and only the left blinker works.
I understand your policy states that I have 3 business days upon receiving the item to contact you if item has been damaged during shipping or isn?t what described in your ad. Today is 22 Dec 2010; I received the item 21 Dec 2010. The ad states that I would have no error lights on instrument panel upon professional installation. Also, it states that all LEDs would work properly with no modifications. There is a very good chance that these lamps where damaged during shipping. All I know is they are not working at all like your ad described. I would like to talk to a customer service representative to get more information on where I need to return this item. Thank You...
- skkons4
To: skkons4
Subject: Re: skkons4 sent a message about 2010 LOOK MERCEDES W221 S550 S600 S63 S65 LED TAIL LAMP #120651490946
Sent Date: Dec-22-10 14:28:27 PST
Dear skkons4,
May I ask what kind of issue you have?
Did you encounter error saying rear side marker, left, right..etc and the top half LED is blinking?
Regards,
Simon
These tailights are not working properly. I went to a professional bodyshop to have installed. The dashboard has taillamp inop light, and they don't light properly. I paid a lot of money for this product. I'll return in same box tomorrow...
- fishcake321
Old 07-23-2011, 09:06 PM
  #348
rmajor's Avatar
www.123mercedes.com
Old 07-29-2011, 12:09 PM
  #349
freightflyer333's Avatar
mercedes benz s550 AMG P3
HELLPPPP
Hey im new to this forum i just picked up my self a S550 p3 package and trying to install the resistors on the wireing for each tail light. i took everything apart yesterday and got stuck. if any one could either provide a diagram or some pictures would really help out Thank you.
Old 07-29-2011, 03:43 PM
  #350
C-DiZzY's Avatar
2010 S550
There not plug and play? It took me about 30 minutes to put mine in
Quick Reply: Updated 2010 w221 taillights on older w221
