Has anyone gotten the ECU reset trick to work?
Old Dec 18, 2009 | 11:06 PM
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
As the title asks, has anyone ever gotten the ECU reset trick to work on their W221? I can't get it to work on this car or the ML (haven't even bothered on the other two yet) and I'm pretty sure I'm doing it correctly. I've tried many times over and over on separate occasions. I know what the difference is like as well as the dealer has done it before on the ML and it was night and day. If anyone has successfully gotten it to work on their W221, please post up saying how you were able to. My car's been babied almost all of it's life and I'd like to reset that.
If you don't know what the ECU reset trick is, you can read about it here.
Old Dec 19, 2009 | 08:24 AM
TDwayne69's Avatar
2012 CLS63 PP
It would be interesting to try this once the snow goes away, I know there's a similar reset procedure for the 7 Series, but you had to hold the gas pedal in for 20 sec. This reset the transmission.
Old Dec 19, 2009 | 12:08 PM
Quadcammer's Avatar
96 and 08 911 turbos
worked on my 220 and 210.
make sure the doors are closed. I also turn off the climate control and comand.
engage the clickdown if the 221 has it for about 20 seconds, and then wait 2 minutes.
Old Dec 19, 2009 | 02:42 PM
QuadBenz's Avatar
Thanks, I'll give that a shot and report back.
Old Dec 19, 2009 | 04:22 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
tried on my S550 several times. just a gimmick. u feel like there is slight diff, but goes away soon. if u r still under warranty the dealer will install new updates for free. that helped big time. the lag was almost gone. just my 2 cents.
Old Dec 19, 2009 | 04:28 PM
jagata's Avatar
S6 LP640 E500
What is the update and what exactly is involved?
Old Dec 19, 2009 | 04:32 PM
I told the dealer it does not shift properly. they flash both the engine and transmission ECU's with latest software from benz. thay also recaliberate the shift points to factory specs.
Old Dec 19, 2009 | 04:44 PM
jagata's Avatar
S6 LP640 E500
Thanks I will tell them that the next time I'm in.
Old Dec 19, 2009 | 05:39 PM
QuadBenz's Avatar
That's what I told them for my ML (it really wasn't shifting properly). They did the above things you mentioned and the difference was amazing. It felt like a whole different car. Essentially, it resets the tranny adaptations, which is what the ECU reset is supposedly supposed to do, but I think it only works on the older model Benz's.
