Problems linking bluetooth with iphone 4
Old Aug 30, 2010 | 04:18 PM
S550's Avatar
Has anyone else had this problem? My 08 S550 recognizes and authorizes the phone and the phone does too but it won't work. the phone shows it as disconnected.
Old Aug 30, 2010 | 04:45 PM
GFEAR's Avatar
MINE WORKS NO PROBLEM WITH MY I4
Old Aug 30, 2010 | 09:52 PM
s600ed's Avatar
2007 s600 2007 cls63
what BT puck are you using?
Old Aug 30, 2010 | 10:05 PM
GFEAR's Avatar
Ill take a pic tomorrow
Old Aug 30, 2010 | 10:34 PM
S550's Avatar
Do I need additional hardware to make it work? What's a puck and what does it do?
Old Aug 30, 2010 | 10:35 PM
szohar's Avatar
s550
I have the same problem.
The dealer told me I need to purchase a different cradle than the one I have today ($499), I cant believe it that I need to change the cradle for iPhone, did you find any other solution?
Old Aug 31, 2010 | 09:23 AM
GFEAR's Avatar
This is the one that works on mine.
Old Aug 31, 2010 | 09:31 AM
S5502007's Avatar
S550 2007
iPhone 3GS OS4.01 Bluetooth pairing issues
I too am having the same issues with pairing my phone with the bluetooth device on my 2007. The blue lights flash on the device but the iPhone does not recognize it.
Has anyone paired with the latest operating system for the iPhone (4.01 I think)?
I have my car in for servicing at MB right now...hopefully they can figure it out.
Old Aug 31, 2010 | 09:45 AM
jprescott's Avatar
ML-350, Maserati Quattroporte
I'm good on an 07' and it's an older puck. Will see how it works with our GL which is newer puck from 09'
Old Aug 31, 2010 | 11:35 AM
Em Bee Lover's Avatar
CL550 1976 450 SL
"Puck" and wireless connections
2007 S550. Same puck as pictured earlier in thread.
When I was stalled trying to get my Motorola hand held to work through the command, I went to this site--wireless4mb.com
The information provided helped me stumble through things. I am up and have never lost the connectivity. Good luck.
Old Aug 31, 2010 | 03:02 PM
TDwayne69's Avatar
2012 CLS63 PP
You have to pair with both the car and the puck. Pair with the car first then hold the star emblem on the puck until it starts flashing and find the device in your Iphone bluetooth settings and select select the device. Once you've done that go into the Command Unit under phone and select bluetooth and authorize your phone. This should completely connect your Iphone.
