Misfire under high rpms
Old Oct 8, 2010 | 03:10 PM
greekviking's Avatar
2007 s600
Has anyone with the V12TT experienced misfire codes under load around 5-6K rpms? My car is an '07 has 61K miles, ran like new. Now whenever I get on it, it throws misfire codes and the motor idles rough. I turn it off, restart and everything is back to normal ?!? What could cause this ? Could it be a dirty fuel filter, MAF sensor, O2 sensors, etc. ..or is it a coil pack. One could spend endless amount of money and time on this and the problem most of the time does not go away. If it was a coil pack, wouldnt it be doing it at any rpm level.? I'm really stuck with this on.
I appreciate anyone with any help. Thanks.
Old Oct 8, 2010 | 03:53 PM
jagata's Avatar
S6 LP640 E500
I do not own a v12 but my v8 had a bad rod position sensor that felt like a misfire, maybe the 2 engines share that same part?
Old Oct 8, 2010 | 04:47 PM
j21importer's Avatar
07 E63, 04 discovery
i have experienced this problem caused by a coil pack. you should have the codes pulled to see what comes up
Old Oct 8, 2010 | 05:50 PM
2007 s600
If I use Star DAC, will it pinpoint the problem or just give you codes? A good possibility is that it could very well be a coil pack if the codes show only one side of the motor. Did anybody get misfire codes from both sides of the motor? I doubt that both coil packs are shot.
Old Oct 9, 2010 | 11:47 AM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Does it happen pretty consistently in 3rd gear? Right around 5600RPMs?
Nick
Old Oct 9, 2010 | 08:32 PM
2007 s600
YES!! Its happens in 3rd gear around 5500 rpms!!? Did you have a similar condition? What could it be . I thank you in advance.
Old Oct 10, 2010 | 06:56 PM
nick 55's Avatar
I'm going to guess you have a valve floating. You probably have a misfire on one cylinder that doesn't occur under normal driving, but as soon as you wind it out in third gear, it starts making a sound like a really crappy running Dodge Viper. On a good note, the parts are cheap, I would replace all three valve springs on the offending cylinder. Labor-wise, you need to find a good V12 tech, because the average dealer tech will want to remove the cylinder head(which involves removing the engine from the car). I've done 2 V12 cars that had the same issue, but one did it at 3k miles, the other at 17k. Let me know if I can help you out any further.
Nick
Old Oct 28, 2010 | 07:42 PM
nick 55's Avatar
Any updates GV?
Nick
Old Oct 28, 2010 | 08:38 PM
2007 s600
Yes. It was a vacuum hose that was causing the misfires. It looks like the small hose on the right side of the engine was dry rotted a little, came loose, and had a leak. Why didnt MB use silicon hoses? why cheap out and go to rubber? I guess typical OEM stuff....but problem solved. Always check vacuum lines in turbo motors, one leak could cause major problems.
Old Nov 1, 2010 | 10:11 PM
V12Godspeed's Avatar
Your worst nightmare...
All BEWARE OF GREEKVIKING
This person scammed me out of 105.00 Dollars, supposedly selling some V12 emblems...I have replied thru various e-mails asking for tracking info...it is the time of day I have not heard from him nor received package.
I will post this in every single forum if i have to and report it to the moderators.
As of this point I am opening a Paypal case for my 105 dollars. If he offers to sell you something beware, you have been warned.
