W221 - SmartTV X-mas sale!
Former Vendor of MBWorld
SLK 55 AMG
Click on the banner above to order!
TVHBMZ1 - SmartTV DVD/TV IN MOTION for Mercedes Designed for COMAND with high-speed CAN (W204, 212, 221 etc)
Compatible with:
S-Class (W221) Model Year 2005+
CL-Class (C216) Model Year 2005+
C-Class (W204) Model Year 2009+
E-Class (W212) Model Year 2010+
MSRP: $189
MBworld member discount: -5%
Total: $179.55
Free shipping to international
PM for discount code~!!
SLK 55 AMG
Turn the whole module off with an easy key sequence. Ideal when letting someone else drive your car.
Also easy to update Firmware:
all you need is computer.
And main focus is unlocking dvd/tv in motion.
and i guess unlocking part is same with midcity engineering.
thats pretty much it.
please check this link for more information.
http://spheremotors.com/accessories/...z/tvhbmz1.html
SLK 55 AMG
Yes it comes with a manual.
and you can download it from here:
http://spheremotors.com/smarttop/mer...z-tvhbmz1.html
S550 4matic, ML350
Guys, I just ordered this. Looks easy to install and a great mod! Treat yourselves!! Cheaper then midcity and other products...
PS: Im not connected to the seller in any way... If it doesnt work I'l let you all know! HeHe!
SLK 55 AMG
Thank you for your order and comments.
This module is better then midcity product.
It's cheaper and has more functions to it.
thank you-
You need to have your MB dealer do a thing called " Telematic update". This allow you to play dvd while in park. This module that the seller is selling bypass the "park mode" so that you'll be able to watch dvd's while the car is in motion.
Can you explain how it accomplishes this feat? My understanding of how these black boxes work is that they trick the command software into thinking that the car is stopped which could mess with the NAV's ability to work properly in some instances.
SLK 55 AMG
S550 4matic, ML350
I believe this shouldn't affect Nav... But I will give everyone a full report when I install mine... And to reiterate, ALL 2007+ S550's either do play DVDs or are able to play after a software update. This update can be done at the dealer and its something that should be done in any case as it enhances functionality of Command in several areas.
S550 4matic, ML350
The Navi device certainly makes use of the speed signal. As long as you have a good GPS signal you may not notice any difference with or without the speed signal. Try areas with poor or no GPS signal. If I would install a speed signal filter, I would use one that can be switched on and off (from the steering wheel buttons).
heres the link:
http://www.wit-usa.com/sms/db/smartt...eration/en.php
S550 4matic, ML350
Hey guys, got a message into the seller... All installed correctly, the light is blinking indicating a correct install and ... Nothin'
DVDs still only play when in park with brake on.
I will PM as well and get back to you all...
S550 4matic, ML350
Yup! Buttons do nothing. Been through the instructions, online, etc...
The LED blinks properly (showing that the install is correct, but the movies will not play video unless in park, and brake as normal.
I may have a bad unit?
I'm waiting to hear back. By the way, have a flashlight and a good work area, the connectors are small and require a lot of patience getting it all wired properly.
Thanks for the tip. I should get my unit tomorrow,and I'll try get it installed this weekend. Hopefully I don't end up with the same problem,because that would suck. Just don't want to deal with the return/exchange if anything. Well let us know when you hear back from the seller. Sorry to hear about the issue man.
S550 4matic, ML350
This product only allows you functionality of TV and or DVD while driving. You have to have the TV and or DVD functionality already. If you dont have tv now, this wont give it to you... So far I'm waiting to hear about why my unit is not working...
