Creaking noise from passenger seats And Dashboard
Old Mar 23, 2011 | 05:14 PM
famous550's Avatar
S550, 2006 Range Rover Sports Supercharged
I have this annoying sound coming from my steering wheel column and the dashboard area. Also my passenger seats has this loud creaking/vibration whenever i go over an uneven road. Been to the dealer 4 times for this issue and still the problem persists, Has someone else experienced this?
Old Mar 23, 2011 | 05:18 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
you know what? I've been experiencing the same thing for my CL55...annoying squeaking sounds coming around the dashboard, windshield airbag area...if anyone can tell me how to fix this I would greatly appreciate it
Old Mar 24, 2011 | 12:35 AM
Chucky300's Avatar
2014 S550
Seats are your seat-tracks.
Check it out - they are cracked. Mine was - and it was replaced. had to fight as it wasn't covered under my extended warranty.
Old Mar 24, 2011 | 04:46 PM
skaminer's Avatar
15 cls 550
I had a horrible creaking noise from the dash. Turned out it was the clear plastic cover over the instruments rubbing against the black plastic holder. A gasket that was supposed to separate the 2 had come off. the dealer glued the pieces together and no problem since.
Try putting pressure on the clear plastic piece and see if the noise goes away.
Old Mar 24, 2011 | 10:45 PM
MBS430's Avatar
S550 , S430
hopefully this helps:
LI46.20-P-048871
Rattling or dull knocking noise coming from the area
of the steering system when driving over rough terrain
Complaint:
Rattling or dull knocking noise coming from the area of the steering system when driving over rough road
Cause:
1. Prestress of steering system mounting bolts too low
2. Excessive play between thrust piece and steering rack.
3. Breakaway torque of inner and outer tie-rod ball joints is too high due to unfavorable tolerance/friction conditions.
Note: If number 3 is the cause, the complaint is of a dull knocking noise. This occurs only at speeds between 5 and 20
km/h. Primarily after the vehicle has spent a period out of use or after driving the vehicle in a straight line for a prolonged
period of time.
Old Mar 25, 2011 | 07:11 AM
HiTach's Avatar
E400S4 '17
My dealer verified a creak, or a "click", from the driver's seat when cornering at modest speeds, or when pressure was put on the side bolsters. They ordered a new seat frame from Germany and replaced it. Problem resolved.
Old Mar 25, 2011 | 11:14 AM
phatisfy's Avatar
S-class
Exact same problem on mine.Also was the driver seat.
Old Mar 27, 2011 | 12:31 PM
famous550's Avatar
Haven't had a chance to visit the stealership but thanks for the replies guys.
Old Mar 27, 2011 | 02:33 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
My dealer claims that the creaking noise is normal wear and tear.
Old Mar 28, 2011 | 01:07 PM
famous550's Avatar
All this dealers are full of shi*.
