2nd time transmission valve body replacement
Old Aug 5, 2011 | 04:31 PM
MBS430's Avatar
S550 , S430
I have 08 S550 (W221) and been experiencing rough shift at cold start.
by "cold start", I mean = vehicle moves off for the first time after being parked overnight.
approx 6 month ago, the dealer installed a new valve body (2202702706)
then problem came back.
Updating transmission & motor software did not solve the issue.
Then, the shop foreman determined that I have an INCORRECT valve body.
WHOA!?!?!, I was like wtf!?!? They themselves installed the alleged incorrect valve body .... Anyway, I decided to not pursue why , I focused more on lets get the RIGHT one now)
Now I have a newer valve body 220270320688
so based on:
DTB S-B-27.19/118a JUN10 – MY-All, Transmission 722.9 in Models 164, 171, 203, 204, 207, 209, 211, 212, 215, 216, 219, 220, 221, 230, 251, 463 ordering notes for Electrohydraulic Control Unit
Control unit 2202701406
replaced by 2202701306 then
replaced by 2202702706 then again
replaced by 2202703206-88
let's see if this is THE one now ....
Old Aug 5, 2011 | 05:10 PM
IDriveAnM5's Avatar
'10 S550 4Matic, '06 BMW M5
Sorry to hear about your situation. It might be a little while before the cold weather is back for you to test it out.
Old Aug 5, 2011 | 05:27 PM
MBS430's Avatar
S550 , S430
thanks M5!
just to clarify "cold start" = I meant, the first gear shift after ~ 6 hr of being parked. Usually in the morning after being parked overnight.
I don't think the issue is temperature related. I would speculate it was more due to ~6 hr being parked and the ATF is "somehow leaked" from the transmission's plate pressure
here is copy paste from service bulletin:
LI27.00-P-048552
Complaint: after a cold start, slippage may occur in in the 2-3 shift when vehicle moves off for the first time
Cause:
Basic charge for the K1 piston is not guaranteed with a cold start. The plate pressure still has to be built up. This can cause the shift operation to be slip once.
Remedy:
Topis is known. A software improvement is being produces.
Old Aug 5, 2011 | 07:17 PM
IDriveAnM5's Avatar
Ok, I see. Seems like this sort of thing should be absent from these cars. But I guess that can be said for many things. Good luck man.
Old Aug 6, 2011 | 07:00 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
I thought this was a problem with the 07's only?
Old Aug 7, 2011 | 08:43 PM
Lenn777's Avatar
2008 S550, 2008 CLK 350
Should I be worried about the same issue?
Old Aug 9, 2011 | 04:55 PM
MBS430's Avatar
S550 , S430
my issue is having rough shift when the vehicle moves off for the first time after being parked overnight. It is so rough that the car actually jolts.
does yours shift smoothly after being parked overnight?
Old Aug 10, 2011 | 08:50 PM
nyca's Avatar
I have a 7G transmission in a W204 C Class - it did this from new, the first cold 2-3 shift holds the engine RPMs a little higher before engaging. After that, it doesn't occur again. Don't waste your time/money trying to get it fixed, unless the jolt is violent and severe. I have 60K miles now and the transmission is running fine even in the presence of this anomaly. You shouldn't be accelerating hard during the first 50 feet driving off on a cold engine anyway, a gentle pull away lessens the "jolt" of this first shift.
Old Aug 10, 2011 | 09:13 PM
Lenn777's Avatar
I'm not having any problems with rough shifts when I go to work. That being said, will I have issues when the weather starts getting cold?
Old Dec 10, 2011 | 10:46 PM
jctevere's Avatar
2012 C250 Coupe
Originally Posted by MBS430
thanks M5!
LI27.00-P-048552
Cause:
Remedy:
Has the remedy been resolved yet? I haven't had time to get into my dealership. This issue is present in my 2009 c300 4matic w204... It started around 30k miles or so, and now at 41k miles, I would say it has gotten progressively worse and is much more noticeable and annoying.
Old Dec 9, 2012 | 12:57 PM
ts350z's Avatar
S550
I just replaced my conductor plate inside the valve body. Spent about $1500 at the Mercedes dealership. I've got my car back for about one month..., still drive kinda rough sometimes.... Seems like lots of people has transmission issue...
Old Dec 9, 2012 | 01:50 PM
konigstiger's Avatar
'71 Pinto
Repair is covered for 12 months/unlimited mileage bring it back, speak with the Service Manager and request MB rep covering dealership oversee/moniter case.
Old Dec 9, 2012 | 01:52 PM
ts350z's Avatar
S550
Thanks for the info
