Illuminated Sills from ForMyMercedes.com
Old Jun 17, 2012 | 12:59 AM
RT2010's Avatar
s550
Has anyone on the W221 group successfully installed these aftermarket sills from this site?
http://formymercedes.com/mb_results....l+Replacements
They are cheap and apparently not as complicated to install compared to OEMs. There are no install instructions that come with the kit but he has provided a link to a thread from MBworld by a guy who did this for his E class several years ago. There may other members who said they installed the same for their E class models on that thread.
I want to know if the same instructions apply for W221 or if anyone here has done this w/o much issues?
Old Jun 17, 2012 | 04:08 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
These dont look that good since they are just overlays. You put them ontop of the old sills. You can have mine with his 4 black boxes if you like....These install very easy. Just conect the cables to the interior light and your done.
Look like these:
http://formymercedes.com/images/W210_Sills.jpg
Old Jun 17, 2012 | 01:19 PM
604benz's Avatar
2015 S550V
Chris where did you buy yours from?
Old Jun 17, 2012 | 10:42 PM
Dr Feltersnatch's Avatar
amg cl/s
Lol aren't those the same ones haha
Old Jun 18, 2012 | 06:39 AM
Ebay...
Old Jun 18, 2012 | 11:41 AM
JT.S550's Avatar
Mercedes GL conversion
I bought mine from Jerry at formymercedes and they are excellent, the
Only thing is you have to wire each unit to each door if you want them to work
Correctly, what I did was ground the wire under neath the front drivers side and
Passenger side then ran wire to each door and tapped into the light under the door when it opens, this will make it illuminate when door opens otherwise you can hook it up to courtesy under the drivers and passenger but both lights will stay on because lights underneath are always on, it took about 3 hrs to do so and it looks perfect and factory like
Old Jun 18, 2012 | 11:53 AM
Pics?
Old Jun 18, 2012 | 12:24 PM
JT.S550's Avatar
Chris I'm going to send you pics in your email, I don't know how to put pics from my iPhone to forum
Old Jun 18, 2012 | 04:58 PM
jbondox's Avatar
beater with a heater
I have done 3 sets from Jerry at formymercedes, and they are perfect. I even ordered one that said Brabus.
Also, I took mine to the interior dome light metal contact (soldered) where the bulb goes in, when you open the doors it comes on, when the dome light is on, they come on, when the lights off, they are off...
the under dash light has 3 volts on it and is not good for the transformer, plus causes the dim underdash light to extinguish when hooked up
Old Jun 18, 2012 | 05:37 PM
JT.S550's Avatar
That's same way I did it I soldered it to the metal where the light is under each door, they come on and off every time you open the doors
Old Jun 18, 2012 | 06:46 PM
604benz's Avatar
2015 S550V
Can u guys post pics and installation instructions on the way u installed them.
Old Jun 18, 2012 | 08:05 PM
RT2010's Avatar
s550
Agree -- if you guys can do a brief summary of your installs, it will be much appreciated.
Old Jun 18, 2012 | 08:15 PM
JT.S550's Avatar
The oem silver sills that say Mercedes Benz you gently take it up(off) then you lay down the sills they sent you, it has double sided tape but before you do that you wanna run the wires , on each side I ran black ground to the front under dash and grounded it, now people say they ran power to courtesy light under dash , the installer I got said that those lights stay on which will keep sills on so I ran red wire through the harness when you open door took off door panels and soldered it to the bottom of courtesy light on the door, they look 100% oem and even guys in dealer couldn't believe it
Old Jun 18, 2012 | 09:57 PM
604benz's Avatar
2015 S550V
How secure are they with just double sided tape?
Old Jun 18, 2012 | 10:10 PM
phatisfy's Avatar
S-class
Any pics of the actual product installed?
Old Jun 19, 2012 | 03:35 AM
Is it LED or plasma light?
Old Jun 19, 2012 | 05:26 AM
marthyh's Avatar
S500
Close-up pix please ??
Old Sep 4, 2012 | 08:13 PM
RT2010's Avatar
s550
How to figure out the right wires to hook up to?
JT.550 / anyone that has done this before
So I just received the illuminated sills from ForMyMercedes last week (it was on back order) and plan to install it soon. I am sure I will find a bunch of wires when I open the door panel so would appreciate some details from your guys.
As I understand, there are 2 connections
1. Ground - Under the driver side. Black wire on sill hooks to this.
2. Power - Each door's courtesy lights. Red wire on sill hooks to this.
Is this correct. Is there an easy way to identify the courtesy light wires - i.e. specific color etc.?
Thanks, RT.
Old Sep 6, 2012 | 05:26 AM
nimski62's Avatar
Thanks, RT.
I just got done installing these, I took a much easier route. I took the rear door handles on the headliner off to access the lights up there that turn on when the door is opened. Also, took the weather stripping off and then ran one wire from the light in the headliner (+ pos) and got ground from one of the metal clips that attaches the rear door sill to the vehicle. I used the same wiring from the rear door sill to the front door sill. I was not comfortable taking off door panels, as its not an easy task on the w221. I am satisfied, and not one wire is visible.
Old Sep 6, 2012 | 05:38 AM
Pics?
Old Sep 6, 2012 | 04:43 PM
604benz's Avatar
2015 S550V
Nimski62 how long did the install take and where did you buy the sills from, can you post some pics.
Old Sep 6, 2012 | 09:59 PM
nimski62's Avatar
Bought from Formymercedes.com.. Took me a solid 4 hours.. Took my time. I will post pics tommorow.
Old Sep 6, 2012 | 10:45 PM
604benz's Avatar
2015 S550V
I just ordered the white illuminated sills, should get them in about 10 days, i'll probably try your method of install as it seems more straight forward.
Old Sep 9, 2012 | 04:23 AM
Mercedes.
Old Sep 9, 2012 | 03:01 PM
604benz's Avatar
2015 S550V
Any pics yet guys.
