W221 DIY replacing rear break pads
Better to ask on a forum or anyone knowledgeable or have a look at the 'wis' then to be sorry later..
Unfortunately haven't done mine yet.. so cannot add anything useful for the OP..
1. take off wheel
2. release pin by using a thin rod and hammer away till the pin retaining the copper spring is release.
3. pull out spring retainer.
4. Pull out break pad sensor
5. using a flat rod pull back the caliper just a bit.
6. pull out the brake pad and your done
7. to replace the new one do everything in reverse.
1. take off wheel
On mine I had to:
1. take off the wheel
2. remove the spring retainer
3. remove the plastic caps on the caliper bolts (2x, behind the caliper)
4. remove the caliper bolts with an allen wrench (7 mm, I think)
5. pry the calipers open with two screwdrivers
6. replace the pads.
The passenger side inside pad had a wear sensor in it that I also replaced when I put in the new pad.
It was a very quick job but it took me a little while to figure out I had to remove the plastic caps on the caliper bolts to unscrew them.
