Reseting Air Bag indicator?
Old Aug 19, 2012 | 09:05 PM
RT2010's Avatar
s550
So I installed paddle gear shifts over the weekend (thanks to the Swede). It looks and works great. I had to remove steering and airbag in order to do this but put them all back in place to the best of my knowledge.
Problem is the air bag malfunction message pops up each time I start the car (that I can click OK button to dismiss) but the red airbag indicator is ON all the time.
Any idea how I can reset this??
Thanks!
Old Aug 19, 2012 | 10:14 PM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
Rt are you sure you installed it back accordingly? to delete the fault you need to use a star diagnostic computer. Is the message in amber?
Old Aug 20, 2012 | 08:08 PM
RT2010's Avatar
s550
Yes, that message is in amber that I can click OK to dismiss. But the air bag icon that shows up is red and stays ON all the time when engine starts.
Old Aug 21, 2012 | 05:13 AM
for safety reason you need to bring it to a qualified technician to check it out to avoid and compromising any safety issues.
it can also mean the installation was not done properly or you might have broke something while dismantling, send it asap to a qualified tech.
Old Aug 21, 2012 | 06:56 AM
BenzV12's Avatar
W212 FL
I swapped my steering wheel and right after the new one installed , I saw an air bag warning too. My MB staff connected a device to my car and he deleted the light by using DAS
Old Aug 21, 2012 | 12:15 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Turning on the car while the airbag is unplugged will create this situation. As previously indicated above, the only way to turn the warning light off (and re-enable the SRS) is to have the code cleared on a MB-star level diag tool. Of course the dealer can do this for you (or a member who has the MB-star) OR .... most upholstery shops and body shops have access to a guy who can do this (generally for a little less).
The way to avoid this is to disconnect the battery (batteries) before you disconnect the airbag (adjust your collumn to full extension for best access to the airbag screws first) And then, do not reconnect the batteries until the airbag is reconnected.
Chris
Old Aug 22, 2012 | 08:03 PM
RT2010's Avatar
s550
Thanks for the info guys. I'll use Star DSS and try to see if message is cleared.
Old Aug 22, 2012 | 11:45 PM
RT do update us on what happen.
Old Aug 23, 2012 | 04:00 PM
Tobby's Avatar
2020 AMG C63S Coupe, Kawasaki ZX10R
It goes away using Star. It's normal that you get a malfunction message and the red airbag lamp after you have disconnected the airbag. For safety causes you have to use Star to erase the message.
Old Jan 5, 2015 | 01:01 AM
mikos550's Avatar
s550
nice
Old May 25, 2024 | 09:41 AM
merrar's Avatar
2016 C300
Airbag light
Hi. Mine is also on. But it happened after I understand my driver seat cover changed. Is there any other way to reset the light
Old May 25, 2024 | 01:43 PM
doni01's Avatar
2013 S550 4MATIC
Star/DAS will reset it.
Old May 26, 2024 | 10:26 PM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
any scan tool with airbag reset capabilities can rest the light
