Vehicle Rising Please Wait! HELP! no RISE!
Subscribe
May 17, 2013 | 01:03 PM
Hi so my rear on my w221 sits a tad lower than the front so I was thinking either mispositioned link or bad sensor. I took the rear sensor off to adjust and replaced it now I have a message vehicle rising please wait when I start the car but the compressor isn't coming on! Any ideas to why my car wont rise? Its sitting on all four on the complete ground
Reply 0
May 17, 2013 | 05:38 PM
Any one? lol
Reply 0
May 19, 2013 | 01:02 AM
Its the fuse and or the pump ??Check the wiring-harness going to the pump under the right front wheel well before to replace anything, this could be oxidised and causing the issue. I have read several occassions on this forum ,that could be it..
Also the pump is a relatively normal 'wear and tear replacement' on these cars.. So would not be surprised if its gone..
Reply 0
May 19, 2013 | 05:56 PM
I just replaced pump and checked fuse , its a ok. It was just working fine before I went under the car now its all the way to the ground and the pump isn't responding...I also checked the relay
Reply 0
May 19, 2013 | 07:13 PM
So after checking this old thread https://mbworld.org/forums/s-class-w...-location.html I found that the 40 amp fuse for the pump wasn't blown BUT just isn't getting any power to it. I think this is why im having this problem. No power to the fuse equals no power to the pump. Any electric people around so I can trace down the problem!?
Reply 0
May 20, 2013 | 10:59 PM
Thanx a lot guys! smh.. turnt out to be an upside down sensor ..
Reply 0
May 21, 2013 | 12:48 AM
Good catch!!! Enjoy the drive.
Reply 0
May 21, 2013 | 10:06 PM
What is an upside down sensor?
Reply 0
Explore
May 22, 2013 | 02:08 AM
Quote: What is an upside down sensor?
It detects if the car is upside down and tells the driver if she does not notice it.
I believe the OP means the level sensor was removed and then installed incorrectly, upside down, which made Airmatic misbehave.
Reply 0
May 22, 2013 | 08:05 AM
Thank you Diesel for the clarification, that was funny. That is what I thought, but was not sure. There are so much about W221 I am still trying to learn.
Reply 0
May 25, 2013 | 01:10 PM
now i'm getting the same message every time i switch on my car as the rare of my car sleep down, but as soon as i switched it on it starts raising. So, I asked a guy who works with MB about that then he replied to me that you need to change them while another one said to me not it only needs a programming ? what do you think of that !!
Reply 0
Jun 20, 2013 | 05:19 PM
I'm not sure if you do have it programmed let me know what went on please !
Reply 0
Subscribe
Currently Active Users (1)
