in the final stage of facelift...few questions i need answers to please
Old Aug 3, 2013 | 10:23 PM
just1time's Avatar
s550
should be finishing the facelift by Tuesday. I have a few questions since I have had no luck with the search function. all help and advice appreciated.
For the drl connection,i will be tapping into the sidemarkers. In dat case, is it ok to simply remove the bulbs from the foglights since i wont be using them (facelift bumpers have no foglight) or will that throw a code. if that the case,where did u guys tie them to?
just1time
Old Aug 4, 2013 | 03:50 AM
Tukmolly's Avatar
2017 E300
I went through the same scenario early this year with my '08 facelift. You can't remove the bulbs. It'll show an error message if you switch on the fogs. The message won't go away even if you turn it back off. Just leave them as is and tie down the harness. Just be aware though, some owners have had issues with tapping the DRLs onto the sidemarker lamps. I personally did the resistor approach. So far, so good.
Old Aug 4, 2013 | 08:45 PM
just1time's Avatar
s550
can anyone who tappedinto the sidemarkers and had issues pleae comment? And anyone who tapped into the foglights with resistors please give details on specs they used.
thanks
just1time
Old Aug 5, 2013 | 12:09 AM
Tukmolly's Avatar
2017 E300
Resistors available on eBay 50Watts, 6 Ohms. Choose the best quality or if you can find Japanese made ones, much better. Make sure you bolt/ screw on these onto the metal frame of your front bumper to distribute the resistor heat. Check out eBay:
http://www.ebay.com/itm/Truck-Auto-Car-DRL-Daytime-Running-Light-No-Error-Load-Resistor-Decoder-2-Pcs-/370749422096?pt=Motors_Car_Truck_Parts_Accessories&hash=item5652633a10&vxp=mtr
Old Aug 11, 2013 | 02:18 AM
just1time's Avatar
s550
okay guys,couple more questions please.
Does anyone know if the 010 s63 front grill will fit the 010 s550 with amg kit? I bought the s63 grill prior to deciding that i wanted the 010 s550 amg kit look instead.
Also, does anyone know if the lower honeycomb mesh grill on my 07 s550 with amg kit will fit the 010 s550 front bumper with amg kit. Or should I expect to buy a new lower honeycomb mesh for the 010 s550 amg kit front bumper.
just1time
Old Aug 20, 2013 | 09:06 PM
azizblue's Avatar
2011 s63 amg
[QUOTE=just1time;5737671]can anyone who tappedinto the sidemarkers and had issues pleae comment? And anyone who tapped into the foglights with resistors please give details on specs they used.
thanks
u will have flicking lights .best way add a relay works 100 %
Old Aug 20, 2013 | 10:32 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
http://www.ebay.com/itm/LED-Daytime-Running-Light-DRL-Relay-Harness-Auto-Control-On-Off-Switch-Kit-B-/360675903532?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f9f5882c&vxp=mtr#ht_3998wt_1397 I used this and tapped into a headlight wire works perfect!
Old Aug 22, 2013 | 08:17 AM
just1time's Avatar
s550
hey
Originally Posted by S500 Man
LED Daytime Running Light DRL Relay Harness Auto Control ON OFF Switch KIT B | eBay I used this and tapped into a headlight wire works perfect!
this seems like a better approach as it is independent of the entire electrical system of the car. it is similar to the hid kits that used to be used to get power directly to hid kits from the battery and skip connecting to headlights.But you said you tapped into the headlight to power them. Why is that? to be able to switch them on and off at will?or is there some other reason?
