W221 / M275 / V12 Ticking Noise...
Old Oct 6, 2013 | 12:21 PM
MJM's Avatar
MJM
W221
Hello Everyone,
I just got a 2007 W221 with the M275 engine / 75,000 miles. I checked the car out and and had the Benz dealer in Minneapolis do the same. Either we both completely missed the tick or it started shortly after I got the car.
The car sat for most of 2013 on the dealers lot not driven more than 100 miles in 7 months.
First thing I did was an oil change with Mobil 1 0w40. No dice, noise still present. I added SeaFoam and was briefly able to stop the tick but it came back.
The tick increases with RPM. Happens hot or cold.
I changed the oil after 100 miles of SeaFoam and went to Pennzoil 5w40 Ultra Euro. No dice, noise still present.
Added Kreen Engine Oil treatment to the oil and have put about 300 miles on the car to no avail.
My Benz dealer doesn't have anyone who has been inside the M275 engine, I'd like to find a dealer or independent who has some experience with this engine. I'm willing to travel anywhere in Minnesota, Wisconsin or Illinois.
Does anyone have input / suggestions? I assume lifter noise is the logical place to be thinking I have a problem, thoughts?
Thank you.
Old Oct 6, 2013 | 07:08 PM
Atcpup's Avatar
S550
Have them check the purge valve on the fuel evaporation system. I had a very similar ticking that you describe and that's what it turned out to be.They also added felt strips to the line retaining clamps. The part number for the valve is 000-470-88-93. Worth a try...
Old Oct 6, 2013 | 08:38 PM
MJM's Avatar
MJM
W221
Thank you for the input, I wouldn't have even thought to go down that route.
I'll book an appointment with the dealer and see where it goes.
I'd be thrilled beyond polite words to not have to start ripping into this engine.
Have a good night.
Old Oct 7, 2013 | 11:45 AM
konigstiger's Avatar
'71 Pinto
http://www.benzworld.org/forums/r230...e-problem.html
Old Oct 15, 2013 | 09:07 PM
Atcpup's Avatar
S550
Any news on the tick yet?
Old Oct 16, 2013 | 10:27 AM
Quadcammer's Avatar
96 and 08 911 turbos
the purge valve tick usually occurs only at idle and does not increase or decrease with rpm.
Old May 23, 2014 | 07:34 PM
MJM's Avatar
MJM
W221
For anyone who was looking for the outcome of this....
It was indeed a broken wrist pin. There was damage to the cylinder wall.
No explanation for why it happened, stock engine.
Old May 23, 2014 | 09:45 PM
Mike5215's Avatar
2016 C300
Yikes. How much is that going to cost? Any warranty?
Old May 24, 2014 | 12:42 AM
kiddkynetik's Avatar
S550
You might want to look up the issues with the 6.3 AMG motors. They have a ticking issue and it's due to the lifters. Symptoms sounds similar to what you are encountering especially when you said that it increases with RPM. I believe the sound was due to the values lifter scratching the value wall. Good luck buddy
Old Jun 16, 2020 | 03:24 PM
mkaysaw's Avatar
2008 s350
Ticking in my 2012 S600 M275
Parked up my W221 S600 in my garage tonight when I realised the engine was "ticking" at idle.
The intensity? of the sound increases and decreases with rpm.
Sound comes from the right side bottom (Near V12 logo on the fender) and also from behind the engine with the hood open. It's barely evident from the left side and not evident when the hood is closed.
Although when the hood is closed, you can hear it coming from underneath the right side of the car if it's parked in a garage, in fact that's where I recorded the sound on my phone.
The wall next to the car is tiled so it reflects the sound more. Sound recorded and attached.
The car has 15k miles on it.
File Type: mp3
Old Jul 12, 2020 | 06:39 AM
pillowshot's Avatar
2007 CL600
​​​Hi @mkaysaw
Did you manage to get to the bottom of your ticking noise?
Old Jul 12, 2020 | 10:33 AM
mkaysaw's Avatar
2008 s350
Originally Posted by pillowshot
​​​Hi @mkaysaw
Hi,
Not yet, I'm still hearing it and it hasn't gotten worse but I haven't had the time to take it in to the Stealership yet. I'm planning to take it in this week and will post an update here.
-M
Old Jul 12, 2020 | 08:29 PM
JohnLane's Avatar
222 S-65
Sounds like a lash adjuster. Relax. Your A/C compressor is louder and it is many many moons from needing attention.
Old Oct 30, 2021 | 10:35 PM
elijahtonys18's Avatar
2007 Mercedes-Benz CL600
Hi,
-M
Have you figured out the issue? i have a 2007 CL600 thats making the exact noise
Old May 19, 2023 | 03:39 AM
Winter63amg's Avatar
Mercedes CL63/65
i am also curious as to the outcome of this tick?
