2011 S550 Intermittent Starting
Old Dec 19, 2014 | 07:02 PM
ftdoan's Avatar
s550
Guys I can't seem to figure this one out.
The car randomly wont start after being driven, turned off, and then tried to be turned back on again. The car would not turn on and doesn't even have a cranking sound. I left the car for 20 minutes and came back and it started again. It seems something is overheating because as soon as I wait 15-20 minutes the car starts just fine. I was able to replicate it twice today within one hour.
First time was driving the car for 30 minutes stopped and went into Fedex for 2 minutes, and the non start symptoms occured. Waited 15 minutes and everything went back to nornal .
Drove the car back too my house which is 10 minutes away turned off and had to wait 20 minutes for the car to engage again like normal.
***Now the car is shutting off while driving, have to wait 20-30 minutes to start back up.
No errors or indications come up and MB can't replicate it. Is this a symptom of CPS failure even if there is no cranking sound? Any help is much appreciated!
Old Dec 20, 2014 | 05:21 AM
marthyh's Avatar
S500
If you hear a 'click' when pushing the button or turning the key; its most likely the starter motor.
If no click ,it could be the starter relay or a fault in the wires to the startermotor.
Or indeed in the startermotor itself .
Old Dec 22, 2014 | 01:01 AM
Nickthegreek's Avatar
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
The symptoms don't exactly match but are similar to having a bad crankshaft positon sensor or camshaft position sensor. Usually it just cranks and doesn't start after turning it off but in your case the fact that it doesn't crank at all I'm not sure. I had a bad camshaft position sensor and my check engine light would come on and off intermitently and I had the no start situation
Old Dec 24, 2014 | 12:00 AM
ftdoan's Avatar
s550
The other day the car turned off on me while I was driving! Same issue as before, had to wait 15-20 minutes car cooled down and started right back up. The car was a little jerky on the throttle but all was normal after driving for a few minutes. No errors have come up yet?
Old Jan 7, 2015 | 12:12 PM
ftdoan's Avatar
s550
It's at the dealership now but of course they can't replicate it and it's not throwing any codes.
The car turned off on me twice while I was driving last week. Had to wait 30 minutes for it to start and ran like normal. When I tried to start it, it was just dead no crank or anything. Any thoughts??
Old Jan 11, 2015 | 07:46 PM
im thinking either crankshaft or camshaft position sensor
Old Jan 11, 2015 | 07:47 PM
...and maybe you have a close to dead battery on top of it
Old Jan 14, 2015 | 01:20 PM
Any updates on the culprit? Very curious to learn what the cause was
Old Jan 14, 2015 | 01:22 PM
I'm starting to also wonder if your alternator or battery might have been the problem. Did it ever say anything about a low battery?
Old Jan 15, 2015 | 09:27 AM
alx's Avatar
alx
you most likely have a dying battery and maybe a dying cps
have the battery load tested and terminals checked for good connectivity. it takes very little wiggle for the terminals to not make good contact when battery is called upon hard
more expensive propositions are an overheating ecu or driving authorization module
