S550 4matic tire size help plz!
Old 06-03-2015, 09:48 AM
Crazey's Avatar
2013 S550, 2002 S500, 1996 3000GT VR-4
I have an S550 4matic. I noticed today that the front tire size is 255/35/20 and the rear tire size is 275/40/20. I thought that on AWD cars, the tires must be the same rotational diameter, and on mine, they're not. Is it different with benz?
Old 06-03-2015, 10:17 AM
Crazey's Avatar
I called Mercedes, and they're like, yeah that's normal. I know on my Lexus, they had to be the same rotational diameter. On my VR-4 they got to be the same rotational diameter.
Old 06-03-2015, 10:28 AM
WHPH28's Avatar
Depends on the weather
OEM - they are supposed to be the same size...technically, they should be 255/35/20 on all 4 corners. People run staggered sizes as long as they are within 3% and have no issues.
Old 06-03-2015, 10:32 AM
Crazey's Avatar
Well i'm no so much concerned about them being staggered. I'm concerned that they're aren't the same thickness, therefore they don't have the same rotational diameter. The width isn't an issue i'm aware, it's the sidewall i'm worried about.
Old 06-03-2015, 10:41 AM
WHPH28's Avatar
The only thing you can do is put 255/35/20 on the rear. You can't run a 275 on the front.
Old 06-03-2015, 10:45 AM
Crazey's Avatar
Again, i'm not concerned about the width. Staggered is fine i'm aware of that. It's the rotational diameter i'm concerned about. 35's in the front and 40's in the rear. Not the width, but the diameter, since it's AWD.
Old 06-03-2015, 10:48 AM
WHPH28's Avatar
So, what is it that you are asking or looking for? Did you use the tire size calculator to see the rotational diameter???
Old 06-03-2015, 10:53 AM
Crazey's Avatar
What? No, lol. the rear are 275/40/20 and the front are 255/35/20. Not only can i tell from looking, but the size says it all.
What i'm asking is, since on Porsche, Mitsubishi, Audi, and Lexus, the same rotational diameter is required on AWD cars, is it the same on Mercedes?
Did someone **** up on my car before i got and put the wrong sized tires, or does mercedes drive train allow for different sizes.
Old 06-03-2015, 10:55 AM
WHPH28's Avatar
Read my 1st reply...that answers your question.
Old 06-03-2015, 11:02 AM
Crazey's Avatar
Your first reply is referring to the fact that they are staggered. Mine are not only staggered, they are staggered with different diameters also.
So basically i'm fine with a different diameter tire on front and back?
Sorry, just really want to make sure, 'cause if i did that on my VR-4 i'd have tranny issues.
Preciate you taking the time and responding.
Old 06-03-2015, 11:08 AM
WHPH28's Avatar
Old 06-03-2015, 12:42 PM
Crazey's Avatar
K, staggered refers to the width of the tire/rim. Staggered means different width tires. My questions has nothing to do with the width of the tires whatsoever. I'm not asking about staggered at all, nowhere in my questions is there a questions about staggered, or about width. I'm completely comfortable with the width of my tires, happy with the fact they're staggered and have absolutely no concern with that.
Let me rephrase the questions. If i was running NON STAGGERED tires, 255/35/20 in the front, and 255/40/20 in the rear, would the difference in circumference matter on a benz?
Thanks anyway.
Old 06-03-2015, 01:02 PM
amgm5s8's Avatar
2008 S550, 2006 911, 2006 M5, 2005 F-150 King Ranch
Go to a tire calculator site...
such as
http://tire-size-conversion.com/tire-size-calculator/
it shows it is a 5.7% difference which is way too much
these are not stock rims that came from factory and the previous owner was unaware of this
Old 06-03-2015, 01:03 PM
WHPH28's Avatar
read the rest of what i said...it doesnt matter if they are staggered or not, it's about the tire size. All you need to do is look at a tire size calculator...
"as long as they are within 3% and have no issues."
Old 06-03-2015, 01:16 PM
1bad540's Avatar
s550 Diamond white amg pano
should prob be 275-35-20, go on tire rack and see the stock size.
Old 06-03-2015, 01:27 PM
Crazey's Avatar
Well the tires are new. So i'm going to have to change either the front, or the back. I'd prefer having a quieter ride. I'm not ripping corners with this thing anyway so i'm leaning for the 40's all around. So, should i go with 35's all around, or 40's? what do ya'll think?
Old 06-03-2015, 03:52 PM
hyperion667's Avatar
Received 3,405 Likes on 2,848 Posts
2012 CLS63
while it's not an 07, I have 265's on all four corners
Old 06-03-2015, 03:59 PM
Crazey's Avatar
I"m not very concerned with the width. What size sidewall are you running?
Old 06-03-2015, 04:49 PM
2012 CLS63
35
Old 06-03-2015, 07:08 PM
Garticus's Avatar
W221/S550
Do you realize the height (sidewall) of the tire depends on the width right?
275 = width (in millimeters)
35 = 35% of the section width of your tire is the sidewall height measurement.
So a 275/35 can have a taller sidewall than a 195/40.
So you SHOULD be concerned with the width as the other number is based on the width.
Old 06-05-2015, 09:27 AM
amgm5s8's Avatar
another problem with current setup...
If your wheels are staggered, when mounting all 4 same size tires will cause rear tires to have stretched look.
Old 06-05-2015, 03:17 PM
Crazey's Avatar
Like i said in every single reply above:
What i meant was that i'm aware having a staggered setup isn't harmful to AWD cars, so i'm not concerned that they have different widths. I was concerned that they have different rotational diameter.
So no, i'm not concerned at all that the back tires are wider than the front.
Old 06-05-2015, 05:05 PM
amgm5s8's Avatar
I think your confusing all of us
Plain and simple for our 4matic setup is you have to run all 4 tires the same size!
Old 06-05-2015, 05:44 PM
1bad540's Avatar
Rears are the wrong size should be a 275-35-20.
Old 05-13-2017, 05:26 PM
rakaye47's Avatar
W205 C400
You ****heads are dumb. The S550 4matic comes from the factory staggered.
Quick Reply: S550 4matic tire size help plz!
