W221 (2010 S550) - Where is the TPMS Control Module
Old Jul 15, 2015 | 09:13 AM
ChesapeakeLimo's Avatar
2019 Maybach S560
Trying to locate the Tire Pressure Monitoring System Control Module. The info I had was that it was under the plate in the front passenger foot well. But NO GO! It's not there.
Can someone tell me where to find it on a 2010 S550?
Thanks in advance!
Old Jul 15, 2015 | 03:21 PM
xabo's Avatar
'20 S63
On the '08 CL65:
W221 (2010 S550) - Where is the TPMS Control Module-209136047_zpszksdc7bw.jpg
W221 (2010 S550) - Where is the TPMS Control Module-209136048_zpsdqveo7bz.jpg
Old Jul 15, 2015 | 08:48 PM
2019 Maybach S560
Yes, that is where I was told it was on my 2010 S550...but it's NOT there (I checked). A guy from the MB Parts Dept told me it was up under the dash on the passenger side around the blower motor. I pulled the cover but I could not locate it there either. MYSTERY!
Old Jul 16, 2015 | 01:47 AM
Diesel Benz's Avatar
Behind the kick panel. Can we have your VIN, checking details?
Old Jul 18, 2015 | 07:39 AM
2019 Maybach S560
VIN: WDDNG8GB8AA342207
Old Jul 18, 2015 | 11:53 AM
konigstiger's Avatar
'71 Pinto
Here is what EPC shows, should be in upper footwell as mentioned.
Attached Thumbnails W221 (2010 S550) - Where is the TPMS Control Module-capture.jpg
File Type: pdf
Old Jul 30, 2015 | 10:27 AM
2019 Maybach S560
So I'm back at the dealer. They called and said the TPMS module is actually mounted in the trunk behind the seat. So I drive 45-miles back here to have the module replaced and programmed. And guess what? They pulled the trunk panels out and IT'S NOT THERE EITHER! The dealer is stumped and they're going to have to go through MB to try to find this thing is they cannot trace it down manually. I gotta admit I'm a bit annoyed with this whole process, but perhaps less-so than the tech charged with this simple 1/2-hour flat-rate repair.
Old Jul 30, 2015 | 12:01 PM
2019 Maybach S560
So, turns-out the control module on my specific 2010 S550 was mounted on a bracket under the car above the rear differential. Posting this update to this mystery in the event anyone else encounters this problem.
