Is this rust on my 2008 S500?
Old Sep 5, 2015 | 01:28 PM
salis's Avatar
CL500 2008 W216
Hi guys,
I just noticed a scratch on the rear wheel arch and it seems like there is a small dot of rust. Is this possible? The car is a 2008 S500. I am attaching a photo below.
Also, I noticed a bump on my front tyre - do you guys think this is dangerous? Should I replace the tyre? Also attaching a photo.
thanks in advance!
Attached Thumbnails Is this rust on my 2008 S500?-fullsizerender.jpg   Is this rust on my 2008 S500?-fullsizerender-1-.jpg
Old Sep 5, 2015 | 02:27 PM
1bad540's Avatar
s550 Diamond white amg pano
yes to both.
Old Sep 5, 2015 | 02:48 PM
salis's Avatar
CL500 2008 W216
thanks, I will change the tyre.
But how is it possible for a 2008 Mercedes to rust? I thought the rust issue was sorted by then?
Old Sep 5, 2015 | 03:09 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Because there is a chip or scratch then went all the way through the paint & primer, that's how.
To repair, just clay bar the area, or use a good polish to rub the rust off. Then dab some touch-up paint into that spot and you'll be good to go. It shouldn't come back.
Old Sep 6, 2015 | 07:34 PM
salis's Avatar
CL500 2008 W216
thanks!
I thought that a Mercedes from 2008 should not rust.. not very impressed..
Old Sep 6, 2015 | 08:51 PM
steveb9771's Avatar
2007 CL550
thanks!
All steel with the exception of stainless will rust if the integrity of the protective coating is compromised. Even galvanized iron will rust if the coating is scratched down to the bare metal.
Old Sep 7, 2015 | 06:24 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Stainless steel doesn't mean that it won't rust , it means that it will rust "less". We see very expensive German stainless steel (medical instruments) rusting sooner or later.
Old Sep 7, 2015 | 08:39 AM
steponthegas's Avatar
2006 M-Class ML350
The tire looks bad.
Old Sep 7, 2015 | 08:50 AM
pleeson's Avatar
2022 GLC 300
thanks!
Look at any car's brake rotor after a wash, exposed steel oxidizes in minutes.
Unfortunately, when it has been left for a while, the rust often extends farther under the paint than you think. You need to scrape the paint back with a sharp edge to expose clean metal, prime and paint the area.
Just dabbing touchup paint won't work -- you'll get a big bubble later on.
Many YouTube videos will show how it's done.
And also agree that that tire is shot -- looks like pothole damage.
Be sure the wheel is round before you put a new tire on it.
Good Luck!
Old Sep 9, 2015 | 09:47 AM
salis's Avatar
CL500 2008 W216
ok, thanks!
Old Sep 10, 2015 | 12:37 PM
salis's Avatar
CL500 2008 W216
Might be a stupid question but how do I know what tyres I need to fit? Obviously I can check the current tyres, but I can't be sure that the previous owner got the right size. I have already checked my manual and official car specs, but I can only see the rim size.
thanks a lot!
Old Sep 10, 2015 | 10:30 PM
steveb9771's Avatar
2007 CL550
The original tire size should be on a data label inside the driver side door jamb.
Old Sep 11, 2015 | 05:57 AM
salis's Avatar
CL500 2008 W216
thanks!
Old Sep 11, 2015 | 09:05 AM
salis's Avatar
CL500 2008 W216
btw, does it make sense to fit run-flats? These should be safer than the standard ones, right?
Old Sep 11, 2015 | 11:13 AM
DaveW68's Avatar
Veteran: Army
2015 S550
They are definitely safer if you're fleeing the scene of a crime and the police set up road spikes to try and stop you. Otherwise, go with regular rubber as the run flats will ride harsh and will eventually wreak havoc on your air suspension.
Old Sep 11, 2015 | 11:17 AM
salis's Avatar
CL500 2008 W216
thank you!
Old Sep 11, 2015 | 09:41 PM
pleeson's Avatar
2022 GLC 300
I had run flats on a BMW 3 series -- terrible.
The first time I hit a little pavement crack I thought something broke in the front end.
A switch to normal tires made the ride and handling much better.
Avoid them at all costs!
Old Mar 8, 2016 | 04:23 AM
shawnepps1's Avatar
2008 CLS 550 (C219)
;l
Old Mar 8, 2016 | 06:18 AM
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2014 S550 (Traded), 2015 GL450
Originally Posted by shawnepps1
IT'S "TIRE" NOT TYRES. Sorry, just had too.
Not unless he is in the UK or any other part of the current or former English Empire.
Old Mar 8, 2016 | 07:56 AM
alx's Avatar
alx
Lol. They do rust. Even if there is no compromise of the coating- rust will just bubble up. It used to take 5 years now it takes 7-10- especially in the regions where salt use is excessive in the winter (like north east).
Old Mar 8, 2016 | 10:32 AM
Quadcammer's Avatar
96 and 08 911 turbos
this thread is painful.
Old Mar 8, 2016 | 01:18 PM
xpl0sive's Avatar
CLS55 AMG
I thought most body panels on w221 were aluminum?
Old Mar 14, 2016 | 02:48 PM
akssdd's Avatar
2006 C230 Sport Sedan
