Air Suspension Fuse Keeps Blowing (40A)
After driving 350 miles I had the following issues:
*After the car shut off: I heard a loud buzzing in front right corner for 40 minutes.
Today:
Drove a few miles and received a RISING MALFUNCTION error.
I restarted the car and the car was able to rise and go down.
Then the RISING MALFUNCTION error came back.
I checked the fuse box and fuse 50 was blown out (*40A)
I replaced the fuse and the car would not go up and the fuse blew.
Put a new fuse in and it blew.
Switched the two relays with two other to no avail.
What would cause the fuse to constantly blow>?
How can I fix this?
Thank you in advance.
On safety- depends. If you are not losing air/ ride height it is ok. If you are losing air and car is getting lower - you can still drive it but it might get too low for safe driving/ handling.
Does it lose ride height or presently sit lower?
Looks like the compressor is right next to the air intake and can be accessed from the top and not under the bumper.
How important is it to replace the relay? Might not arrive due to Christmas.
Are there greater issues that cause the compressor to fail?
Btw an 07 airmatic compressor is just about overdue
Replace compressor and see if it still blows the fuse.
If it does blow the fuse - the next culprit is is the fuse block. Needs to be removed and inspected for corrosion, etc.
If it works, you are not done. Park the car over few days and see if it sags. If it does it is prolly the shock in that corner. You have to address it as otherwise the new compressor will fail prematurely.
Good luck
Now I can't get the rise button to work (red light won't come on). Also the traction control button won't work either.
Good thing is the compressor pump doesn't blow instantly.
Is there another fuse I need to check?
Which fuse or relay controls.
Air suspension appears to be good. Three fingers between tire and tire well for all four tires.
how do I know if I have a leaky strut? should I measure and see if it's lower after sitting outside all night?
Thanks again for all the help.
$452 for compressor/2 relays/40a fuse = partsgeek.com and 6 hours of time.
Not too bad.
