Transmission issue need help ...
Old Dec 22, 2015 | 01:17 PM
jj94587's Avatar
S550
Hello everyone i'm new member owns 2010 S550 with 43000 miles for a year now. Have transmission issue with the car went to dealer 3 times still same problem they changed valve body,transmission mounts and they did shift adaptation. The car still jerks in S mode 1st and 2nd gear and its not that noticeable in D but its there. Dealer said they can't figure out what is wrong with it .Talked to service manager he said bring it back they will check again . Not sure what to do it does have CPO warranty 2 more years . Please help..
Old Dec 22, 2015 | 02:16 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Next step is a MB factory rebuilt trans. They are around $3800 plus labor for the install. Your warranty will pay for it.
Old Dec 22, 2015 | 04:27 PM
alx's Avatar
alx
They need to go on the road and perform custom adaptation for the troublesome shift. It is done with two techs and star/ das plugged in.
Old Dec 22, 2015 | 05:53 PM
jj94587's Avatar
S550
alx thanks for the reply . They did custom adaptation already but still have problem . Just wondering if anyone else have this problem.
Old Dec 22, 2015 | 09:26 PM
Mike5215's Avatar
2016 C300
A used car that's still under a manufacturers warranty is subject to the Lemon Law. Typically 3 unsuccessful visits to fix the same issue without success is a threshold to trigger the law.
Also, a total of 30 shop days for any combination of issues.
Old Dec 22, 2015 | 10:37 PM
alx's Avatar
alx
Only for the original owner...
On the subject of a particular bad shift - did the dealer inspect the solenoids for debris on the screens? Also I assume the updated the tcu to latest revision.
Old Dec 22, 2015 | 10:45 PM
Nickthegreek's Avatar
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
Vehicle jerks during gearchange, hard 1-2 and 2-3 shifts, torque converter lockup clutch (KuB) not engageable
Themen-Nummer LI27.20-P-051537
Version 1
Konstruktionsgruppe27.20 Torque converter
Stand 08-07-2012
Gultigkeit Model designation 212, 216, 218, 221, 251 and 164 with automatic transmission NAG2FE+ (identifiable by EHS part no., starting with A 212 ...)
In combination with OM 642 LS up to transmission sequence no. 3.154.598 up to transmission sequence no. 3.166.389,
Anderungsgrund
Beanstandung:
Vehicle jerks during gearchange or has hard or slipping shifts. In some cases the torque converter lockup clutch (KuB) cannot be actuated.
The following fault codes may be stored in the transmission control unit:
2783, 0741, 0894, 0893, 0735, 0734, 0733, 0732, 0731, 0729, 0606, 076F
Affects veh. up to production date 10.01.2011
Affects veh. upto production date 10.01.2011
Ursache:
Torque converter lockup clutch (KuB) cannot be actuated due to a restricted filter in the KuB valve.
Other valve filters, e.g K1 control solenoid valve (Y3/8y2), may also be restricted with wear debris.
Note:
Only replace solenoid valves which can not be cleaned, up to a maximum of 4 solenoids
Abhilfe:
Removal of EHS and removal of all valves from the EHS to evaluate the contamination of the valve filters. Please ob serve AR27.19-P-021 2A.
Install repair filter A 221 277 00 00.
The filter is only valid for NAG2FE+ with OM 642 LS up to transmission sequence no. 3.154.598 and M278 up to transmission sequence no. 3.166.389.
Replacement of the torque converter is not necessary if this repair is
performed
Important:
It must always be ensured that the valves are installed correctly as each valve has a specific characteristic.
The transmission magnets must always be replaced
Finally re-adapt only the specific problem gearshifts.
Yeah sounds like it could be a dirty/bad solenoid
Old Dec 22, 2015 | 10:54 PM
also did they adapt the lockup torque converter clutch
Old Dec 24, 2015 | 09:16 AM
Shukla's Avatar
Mercedes S550 2007 model
Class Action for transmission problems
My S550 2007 model has transmission problem. I bought the car new in 2006. The car has been services regularly and has only 31600 miles after 9 years. While driving last week, the car got stuck in first gear. I wrote to MB about the problem. They say the problem is mine as it is out of warranty. It seems that 2007 models S550 have an inherent problem of the transmission. MB should replace these transmissions at their cost. We buy these vehicles because of the quality they promise. Maybe a class action suit can be made? Do I have the support. Maybe we shall not win, but the problem shall be highlighted. It is ridiculous to have transmission problems in 30k miles.... Please share your thoughts
Old Dec 24, 2015 | 10:47 AM
MrRat's Avatar
2018 E400 Coupe | 2021 Volvo XC40 Recharge
Jj94587 has a specific issue that is different from your issue. Nick has provided relevant information that may assist in fixing that issue.
For your issue, it is unfortunate to have a transmission problem. I would suggest that the first thing you do is bring it in to either the dealer or a qualified independent for a diagnosis. You may be able to use the shift paddles to drive to the repair facility but you may do additional damage by continuing to drive it in its present condition.
Your car is nine years old and has no warranty. These cars are expensive to purchase, maintain and own. In some cases goodwill on much of the cost to repair is extended by the dealership you use. But you can't expect that, ask nicely, make your case, call Customer service.
From my reading of past similar issues, if you just paid to have this fixed, it runs something like $1200-$2000. You purchased the car new, now at nine years it requires a repair. If you let it go it will cost $6,000 for a new transmission.
