Class Action proposal for transmission problem for S550
I agree that it shouldn't require a transmission repair at 30k but things do break on a nine year old car sometimes. If you don't have a warranty, you are responsible for the repair.
Sometimes the dealership will extend goodwill on some repairs. The path to that is not an angry demand but a friendly discussion with the SA, maybe the customer service rep as well.
These cars are safe, drive and perform really well, and have nice furniture. They do require repair more often than a mainstream high volume sedan like a Honda Accord or a Toyota Camry.
I paid to have a timing belt service done on a 2005 VW Phaeton, it was about $2,000. If it happened to have 30,000 miles I would still have had to to do it. A $1200 repair on a nine or ten year old $100,000 car should not come as a surprise. Parts deteriorate with age and sometimes cause a failure. I have essentially the same car. I have no expectation that Mercedes is responsible for any parts failure well out of warranty. I don't mind pursuing a goodwill repair on an issue that might have been covered by a TSB/DTB. I have no expectation that they will cover something but would appreciate it.
I would think if you continue to reset and drive the car when it's getting stuck in first gear, you will be replacing the transmission rather than just the conductor plate.
Bring the car in for diagnosis, talk to the service advisor, call customer service. Writing a paper letter to corporate is not likely the path to a goodwill repair.
I would guess that the conductor plate is likely being sold at a discount to the cost to produce, which is likely why they also restricted the availability. Perhaps they could goodwill repairs for those transmissions in the known defective range.
The other issue with the defective bearings in the transmission is the more troubling issue. In this case there is no fix available short of a rebuild. Here is where there has been some goodwill applied in some cases, but it would be more useful to define some criteria on the period of extended coverage that may be offered. Alternatively the rebuilt transmission part could be offered at a steep discount or free for transmissions in the defective range.
conductor plate? almost every 7g tranny is guaranteed to fail one or more of the hall effect speed sensors (the turbine one is the most common) in the conduit plate. once it fails you have two options- DIY removal of conductor plate and sending to a vendor for repair ($300 for repair and $150 for new fluid/gasket/filter/bolts) or dealer replacement which requires scn coding - about $1800.
