View Poll Results: Guess cost of new battery for 2010-2013 s550?
200
4
8.70%
300
14
30.43%
400
28
60.87%
Voters: 46. You may not vote on this poll
Guess how much dealer wants for a new battery (2010-2013 S550)
Old Nov 10, 2016 | 10:46 AM
Nuru's Avatar
S350 BT 4MATIC
Originally Posted by DaveW68
This H8 AGM is the exact same battery used as the accessory battery in the pre face-lift cars. I like the idea of having a separate starter battery. My original accessory battery lasted 10 years, while the original starter battery got 9 years of use.
That does sound like a solid design.
Old Nov 10, 2016 | 10:55 AM
Nuru's Avatar
S350 BT 4MATIC
I called Mercedes (MB mbrace) for help when my battery went down at home, and they came out and quoted me $293 for a replacement OEM battery installed. If I would have went into the dealer to pick it up myself, the cost was $600. Luckily I did not need the battery replaced.
Old May 14, 2017 | 04:45 PM
jbarhorst's Avatar
2018 S450 4Matic, 2020 GLE450 4Matic, 2010 S550 4Matic(sold), 2012 ML350 4Matic(sold)
Getting ready to replace the original battery in my 2010 S550 (67,000 miles). Does anyone have any negative comments about the AGM batteries from an auto parts store instead of getting one from the dealer? Looks all positive so far on this thread.
Tom
Old May 14, 2017 | 06:33 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
No problem with aftermarket units. Batteries plus has one for about 140 bucks that looks to be exactly like the OEM one. That's what I did and it works perfect. Fitment is exactly the same. I would guess it is one factory that churns them out and then different companies slap a sticker on them.
Old May 14, 2017 | 06:41 PM
ItalianJoe1's Avatar
2003 CL 600
Originally Posted by 1bad540
does the car need to be programmed after a battery swap like the 7 series do?
Just as FYI, they do need to be reset after battery replacement. It doesn't matter really, but there's a battery life counter that records how much power has gone in and out of the battery. When you replace it, it's supposed to be reset via SDS, so the car knows it's a new battery and can charge it accordingly. Older batteries are charged more gently to preserve their lifespan, so if you never reset it and the car thinks the battery is still 6+ years old, it will never utilize it 100% until it's been reset. That's why replacement batteries don't last like the original, the car is trying to softly charge an "old" battery that isn't actually old.
Old Jan 15, 2021 | 10:47 PM
gcwill3's Avatar
Mercedes Benz S 550
Battery Replacement S550
I own a 2010 Mercedes S550. I need to replace the car battery. However the battery didn’t have a cover on it. Should the there be a cover on my battery?
Old Jan 15, 2021 | 11:09 PM
  #32
lkchris's Avatar
'10 CL550, '12 GL550
$215.38
https://www.mbdirectparts.com/v-2010...rical--battery
I just mail ordered a battery for one of my motorcycles. $194
Old Jan 15, 2021 | 11:13 PM
  #33
lkchris's Avatar
No, just a little cap over the positive terminal
Old Jan 16, 2021 | 12:30 AM
  #34
mcypert's Avatar
2007 S600, 911 & XJ8
On my second starter battery in 6 years. First from dealer >$200. Second, from O'Reilly's; cheaper than dealer, but not much. Identical and, O'Reilly's is more convenient but O'Reilly's didn't have the starter battery 5 years ago. Good to know they do now. I think they have the trunk battery too. How the heck long do those last? I've never even seen mine.
Final note, starter batteries fail without a bang, whimper or even a click. Even static voltage seems normal!!! Ask me how I know... $135 tow and getting ready to check, R/R starter before I discovered it was Just the battery.
Regards... Mark
Old Jan 16, 2021 | 07:00 PM
  #35
gcwill3's Avatar
Mercedes Benz S 550
Thank you
