Engine Issues
Tumble flap shafts sticks in non actuated position.
Compression test next.
What would cause this code? Would it cause a misfire?
Well.. Let me tell you.. We did full engine static compression test.. Good, swapped the coils, swapped the spark plug,swapped the fuel injectors , 5 -8 , all good.. Same failure.. Cyl #8 , probe the engine computer to see if it's was sending signal to injector.. Ok. On the dynamic compression test.. It was 65psi.. While the others was 85.. We will do a leak down test next.. Narrowing down a little at a time
Manifold is coming off so he will see.
Brainstorming if it's anything else additionally
0851 P0444 Y58/1 (Purge control valve): Open circuit / Switchover valve permanently closed (P0444)
0629 P0300 Misfiring (P0300)
0630 P0300 Misfiring (P0300)
0632 P0300 Misfiring (P0300)
0657 P0307 Misfiring of cylinder 7: Damages TWC (P0307)
0658 P0307 Misfiring of cylinder 7: Worsening of exhaust emission values (P0307)
0660 P0307 Misfiring of cylinder 7: Worsening of exhaust emission values after engine start (P0307)
0661 P0308 Misfiring of cylinder 8: Damages TWC (P0308)
0662 P0308 Misfiring of cylinder 8: Worsening of exhaust emission values (P0308)
0664 P0308 Misfiring of cylinder 8: Worsening of exhaust emission values after engine start (P0308)
Next step, swap coil packs to different cylinders if fault code follows, replace affected coil packs. If not and engine # is within range, perform compression test “may” be cylinder head. See bulletin here: https://mbworld.org/forums/cls-coupe...ml#post6857762
Would this item be excluded in an aftermarket warranty? Exclusions include burnt valves and valve grinding.
Would spraying some sea foam help as a temporary fix? How else could you treat the valves?
head needs to come off and machined/ new guide inserted. cam lobes need to be inspected for abnormal wear.
Are we talking 4K? 5K? 6K? More?
