Vibration In Steering Wheel @ 65 mph and during braking
Old Aug 27, 2016 | 11:05 AM
subterFUSE's Avatar
2018 S560
2012 S63 AMG
31,000 miles
I purchased this car in February with 24,000 miles. Got brand new tires on it then, and also put on new front brakes.
The car has always had a minor, but noticeable, vibration in the steering wheel around 60-70 mph. Below 60 it does not vibrate, and above 70 it does not vibrate.
There is also a vibration in the wheel during braking.
I have had the wheels balanced. Alignment done twice. New front brakes. New rear brakes.
Despite all of this, I STILL have the vibration.
What could be causing this?
I have 2 Audis and a Lexus, and none of those cars ever have a vibration like this Mercedes that would have cost more than any 2 of those other cars put together.
Any ideas?
Old Aug 27, 2016 | 12:02 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Sounds like warped rotors. I put slotted drilled rotors on my 2012 along with new tires and it is smooth as silk at all speeds.
Old Aug 27, 2016 | 02:51 PM
subterFUSE's Avatar
2018 S560
all new brake rotors on the car
still vibrates
Old Aug 27, 2016 | 02:59 PM
Bluemax's Avatar
15 S550 Daily 96 Dodge Viper GTS
Bent wheels. Have them checked..
Old Aug 27, 2016 | 05:56 PM
subterFUSE's Avatar
2018 S560
3 of the wheels are good. There was 1 wheel that was very slightly bent but I had repaired.
I guess the repair didn't work?
Old Aug 27, 2016 | 07:28 PM
Nuru's Avatar
S350 BT 4MATIC
Actually rotors don't get warped, they get deposits built up on them and then they will require resurfacing.
http://www.stoptech.com/technical-su...nd-other-myths
Try your spare or another wheel in the position where the repaired wheel is currently located. If the car runs smooth with the replacement wheel, then you have isolated the fault.
Old Aug 27, 2016 | 07:32 PM
superpop's Avatar
Rotors do warp if they are heat cycled to fast. When you changed the rotors did the installer clean up the hubs of any rust or debris that could cause the rotor to seat just a bit off.
Old Aug 27, 2016 | 11:07 PM
Bluemax's Avatar
Have a different shop check the run-out. I think you will find your problem.
Most shops do cosmetic repair and never check the run-out after the repair is complete. I had the same issue with my AMG wheels on my S550
Old Aug 28, 2016 | 08:39 AM
subterFUSE's Avatar
2018 S560
What kind of shop can do a proper repair to a wheel?
I don't think my local Mercedes dealer is up to the task.
I might even have to drive 4 hours to Atlanta to find someone qualified?
Old Aug 28, 2016 | 09:43 AM
sloanbj's Avatar
'72 Fleedwoot
Have you had your alignment checked? Was the car ever as smashed in an accident?
Old Aug 28, 2016 | 10:11 AM
subterFUSE's Avatar
2018 S560
Alignment has been done 2 or 3 times since February.
No wrecks that I am aware of, but it's a used car to me so can't be 100% certain of that. Carfax is only as good as the reporting.
Old Aug 28, 2016 | 12:43 PM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
You need a shop that specializes in wheel repair. NOT a shop that sells wheels and tires. I did a google search and found three shops like that in your area.
Old Aug 28, 2016 | 05:55 PM
Bluemax's Avatar
This ^^. Just ask the shop if they check the run-out. And ask them what run- out they find acceptable. Should be know more than .001-.0015 max.
I would be up front with them and tell them a repair was done and a vibration is still present. let them check them right in front of you. And also have them check the front and rear of the rim. if they know what there doing they will find it quick....
