Goof Off on body?
Old Jan 14, 2017 | 11:57 PM
belanger's Avatar
2012 S550
Question Goof Off on body?
I have some berry(?) stains on my hood that aren't coming off with water and elbow grease. Wondering if I can apply a bit of Goof Off or will it damage the finish?
Thanks much,
MB
Old Jan 15, 2017 | 12:56 AM
DaveW68's Avatar
Veteran: Army
2015 S550
You can try using a compound followed by a good polish on it to see if that will get the stains out. If not, then you can go to a 2500-3000 grit sandpaper and try wet-sanding it. That will not harm the clear coat, but will need to be followed up by compound, polish, and wax to bring back the luster.
Old Jan 15, 2017 | 02:38 AM
belanger's Avatar
2012 S550
Thanks for your answer, Dave.
Do you have any idea whether something like Goof Off will damage the clear coat?
Thanks again,
MB
Old Jan 15, 2017 | 03:05 AM
Eric LeClair's Avatar
Civic 2001
@belanger - Wow berry stains stuck on the hood? Surprised they are actually sticking. I think Goof Off might be to strong. You need something with organic ingredients. Don't use anything with 'chemicals'. Please keep us posted. Goof off sounds like that video game I recently played while wearing a SubPac.
Old Jan 15, 2017 | 09:36 AM
DaveW68's Avatar
Veteran: Army
2015 S550
You can try using a clay bar too.
Old Jan 15, 2017 | 09:46 AM
Mike5215's Avatar
2016 C300
Mercedes uses a catalyzed clear coat, so you can get pretty aggressive with solvents and never touch the clear. Acetone gets out everything, but Goof Off should work too. Try some on an inconspicuous area (underside of the decklid, etc) and make sure it wipes away clean and doesn't gum up.
Old Jan 15, 2017 | 10:49 AM
E55Dimon's Avatar
E63S
You will be fine using it, just make sure to rinse the area right away and wax afterwards. Good luck!
Old Jan 15, 2017 | 04:20 PM
Nuru's Avatar
S350 BT 4MATIC
That's good info, i have a few splashes of whatever on the car and it comes off with water and cloth, but it takes a while, I was a little noid about using solvents on the finish.
Old Jan 16, 2017 | 10:38 AM
belarus27's Avatar
2010 e550 p2
yes you will be fine , just after you done , make sure to clean/wipe any left excess of goo gone.
Old Jan 18, 2017 | 08:31 AM
1bad540's Avatar
s550 Diamond white amg pano
Oh god, are you guys nuts? wetsanding for stains? use the correct stuff. Meguires step #1 paint cleaner will get mostly everything off the paint safely.
