2008 S550 Glove Box 30 pin connector replacement
Old Mar 12, 2017 | 04:32 PM
Ddragon900's Avatar
2008 S550
The 30 pin connector cable in the glovebox does not work and I'm trying to figure out how to replace it. Does anyone know how to get this done.
Thank you in advance, I've been googling this for two days and haven't been able to find instructions. The cable goes through the left side of the glove box into the dash.
Old Mar 12, 2017 | 04:37 PM
Ddragon900's Avatar
2008 S550
This is a picture of the cable.
Old Mar 12, 2017 | 06:20 PM
Mike5215's Avatar
2016 C300
That's some sorta aftermarket doohickey. You'd need to remove the COMAND module (the CD changer assembly) to get at where that damaged cable terminates at the other end. Not hard.
Tutorial:
Post a pic of the COMAND end of the cable.
Old Mar 12, 2017 | 06:31 PM
Ddragon900's Avatar
2008 S550
Thank you very much for the quick response. I will give it a try.
Old Mar 12, 2017 | 11:14 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
That is not an aftermarket cable,it is the original IPod cable,how do you know it is not working ?
Old Mar 13, 2017 | 10:36 AM
Ddragon900's Avatar
2008 S550
I tried using an iPod and also a Bluetooth adapter and they won't power up. I did found a post stating that the white connector on the cable won't work with newer devices because apple changed the charging voltage at some point. It said to switch the cable with part #B67824531A. I ordered one online and will update this post when I get it installed.
Old Mar 13, 2017 | 10:40 AM
Ddragon900's Avatar
2008 S550
Here is where I got my information from: https://www.commandonline.co.uk/ipod...ging-lead.html
Old Mar 14, 2017 | 03:44 PM
DaveW68's Avatar
Veteran: Army
2015 S550
That cable looks beat to sh*t. I'm not surprised that it doesn't work. You can pick one up on eBay.
Old Mar 14, 2017 | 07:49 PM
Mike5215's Avatar
2016 C300
Yeah, by aftermarket I meant the 07-09 didn't ship with the MultiMedia interface standard like all the 2010+ got. They started selling a dealer installed retrofit at some point. I guess that's what one looks like.
On the 2010+, there's a female 30 pin port in the top right of the glovebox and you had to get whatever MMI cable your device required from MB. So when the pin-outs changed on the IPhone 4 you just needed to swap the little cable vs pulling out COMAND.
Old Mar 15, 2017 | 08:16 AM
tx170754's Avatar
On my 2007 CL it is called an "IPod integration kit" and it was made by Mercedes, it also came with a small instruction manual with Mercedes logo. I have attached a Bluetooth dongle to it to stream music from my I phone, works perfect.
Old Mar 15, 2017 | 08:32 AM
Ddragon900's Avatar
2008 S550
That's good to know, thanks. My cable is in really bad shape so I'm hope that's the problem and not the module. New one should be here tomorrow.
Old Mar 17, 2017 | 08:48 AM
Ddragon900's Avatar
2008 S550
I got the new cable (part #B67824531A) installed yesterday and everything is now working.
Thanks for all your replies.
Old Dec 31, 2018 | 03:28 PM
Negasi Tsaudu's Avatar
2009 Mercedes S550 4matic
Where the hell is the iPod integration module?
Where is the iPod integration module located? I’m trying to replace the cable that goes into the glove box since the head is screwed up but I can’t find where I’m supposed to disconnect the other end.
