Ebv Abs and Esp unavailable Diagnostics / rig test
Old May 18, 2017 | 10:54 AM
tariq malik's Avatar
Mercedes s320 cdi
Help
I have a Mercedes w221 58 reg and yesterday my rear air suspension gave up on me. I called out the AA who advised the sensor bracket had rusted and could only locate half. He adjusted my suspension to high and then followed me home. I checked the forums and managed to locate the part for £20.00 from main dealer and proceeded in my car to Halfords. They struggled to put the sensor on due to little space to move. But on taking the car off the ramp the car still was high so he went on his machine and slowly very slowly the suspension adjusted to ultra low rider mode at the rear then the above message appeared. They huffed and puffed tried re diagnostic removing any daul codes then it went in to test drive mode what ever that is but then said sorry mate main dealer reset.
I called the AA and advised what happened and was directed to a Mercedes specialist who advised that as the abs light was on as well the and sensor was damaged causing the issues as the car is not apparently in workshop mode.
The part has been replaced and I can drive the car even if the rear is like a lie rider. Can any one suggest how I can reset the mode I have started the engine moved steering to right all the way and left many times but messages stays on. Help as I don't want to pay £££££ for a fault that was not mine as there were no lights on before I took it to Halfords
I appreciate the length of this post is long but I thought I would list the whole scenario
Thank you in advance
Old May 20, 2017 | 11:43 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W221 forum...
Old Jun 30, 2017 | 01:39 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Originally Posted by tariq malik
Help
The "Test rig" message is usually an indication the vehicle is in dyno mode.
Old Jul 13, 2017 | 12:20 PM
bfdez's Avatar
SLK200 2008
EBV, ABS and ESP unavailable Diagnostics/rig test
This happened to me with my C280 W204 (Yr 2009): After scanning with an iCarsoft MBII. "EBV, ABS and ESP unavailable Diagnostics/rig test" message appeared. Checked it, and "DTC 5410 Road test: ACTIVE" appeared in my scanner.
Following the instructions on it for resetting "ROAD TEST" status, I did precisely the following in a place with enough space and level pavement:
1.- Stop car with front wheels in straight position and geared at P. ABS light is ON and ESP light is OFF. Parking brake released.
2.- Actuate the service brake and shift to N. Release service brake and push the ESP button. The ESP triangular light flashed and then lit steadily. Immediately, shift to D. Move straight and turned 1/4 of a circle (left or right) with the steering wheel turned >90°.
3.- Stop by using the service brake while straightening the front wheels. The ESP light flashed and ABS light was still ON. Shift to N, and release the service break. The ABS and ESP lights went off. The "EBV, ABS and ESP unavailable Diagnostics/rig test" message disappeared.
If not working, try again. Be very precise on these instructions.
Hope this helps.
Old Oct 2, 2017 | 11:08 AM
topcat2001's Avatar
slk
Thanks a lot for this bfdez. I had the same issue after I used the MB II on my 2005 SLK 55 and was able to resolve using your instructions. Did you end up keeping the MB II? Is it really useful? This incident has made me sour on it and I'm not seeing too much value in it overall.
Old Oct 2, 2017 | 12:10 PM
bfdez's Avatar
SLK200 2008
Yes, I kept the MBII scanner.
Yes, I keep my MBII scanner. Originally I bought it to locate an ESP problem related to the steering wheel angle sensor of my SLK200. I saved around USD1,000+ fixing that single problem with the help of this scanner and some YouTube information I gathered. It has also been helpful locating a faulty oxygen sensor in my brother's SLK230. Yes, I was disappointed when this issue appeared, and no answer from the MBII manufacturer when I inquired.
Old Oct 18, 2017 | 03:38 PM
jneal3110's Avatar
04 C32 AMG (sadly sold), 05 CLK55 Cab, 08 R350 4Matic, 15 GLA250 (sadly bought), 75 VW Westfalia
Thanks for this, I'm experiencing the same issue and will give your fix a try. One question: did you have the MB II scanner hooked up when you ran through the steps?
Old Nov 25, 2019 | 10:46 PM
dan9100's Avatar
CharlesStyncOB
2011 S550 .This is the same "message" that was no my dash. I ran the iCarsoft MB v2 scanner to clear a few codes and then this happened. The iCarsoft will not clear this code. I used your method you have, and like you say try again. Many attempts and it finally cleared. I am sure the problem is caused by this scanner.
Old Jul 28, 2020 | 12:00 PM
robert romano's Avatar
clk350
I have a 2008 Mercedes CLK350, I pulled several fuses to check them for a different reason,got in car and ABS,ESP INOPERATIVE DIAGNOSIS/ RIG/TEST light came on, the Tran won’t come out of park ( unless u push button in shifter cavity) no cruise control,but drives fine. What does the this mean, can’t seem to find anyone who knows
Old Jul 29, 2020 | 01:59 PM
BOTUS's Avatar
S500
very common faults on a merc
ABS sensors fail all the time
and or gearbox fun with controls issue and or ignition switch failing also std
Old Nov 17, 2020 | 12:56 PM
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
i tried the rig test directions but when I press the ESP Off button it just blinks and then goes off...it never goes solid.
Old Nov 18, 2020 | 09:02 AM
BOTUS's Avatar
S500
look at live data for the ABS sensors... one is probably being odd, fit 4 new ones - if close to 10 year mark just fit them will be dead next week anyway, even if that isn't todays fun
