Multi-Contour Seats
I am the new owner of a 2012 S550. I learned a few days into ownership that the front seat Multi-contour seats we not working properly. Neither seat massage functions nor airbags functions were working. After a bit of reading and troubleshooting I found that fuse #127 In the rear seat storage compartment was blown. Replaced and blew again after power up. I assume this is this control power for these functions. The only other function that isn’t working is the rear headrest retract feature. Any assistance in narrowing this down is much appreciated
If anyone could help out with a wiring diagram it would be much appreciated. My car is a 2012 S550 4.6L with multi-contour seats. I am particularly interested in where the load side of fuse #127 from rear seat storage fuse block goes. This fuse is blown and neither of my front seat work as far as massage or any airbag adjustments.
I assume this was caused by the water that was introduced into the pump
This is what the pieces should look like. One solid impeller with pieces that go into the slots
I will continue my search. Thanks in advance for any advice.
much apprciated. I have new pump assembly coming Friday. Picked it up on Ebay for $150. I feel good about having a good fix. I will check the reservoir for whatever valve was supposed to drain the water. I understand water being normal in any compressor system. This car was a Florida car which might explain a surplus of water. I don’t foresee it being that much of an issue here in AZ... Thanks again. You’ve been a great help in me understanding the system
Does anyone know which pins on the 4 pin connector to jump to turn on to bench test? Pin 3 is power i believe pin 1 is ground. What I don’t know is which pin to jump to turn on. I don’t want to open case as it has “void if removed” sticker.
If there is an air leak under a seat pressure will fail to build and the compressor will cut off due to thermal cutoff. That was my problem, a broken air hose under the seat combined with the fact the car was programmed with the incorrect seat codes within DAS/STARS.
Just shooting ideas out there for you to check.
As for the doors, etc. has no effect. The car measures when you step in and thinks "hey, the tank is low, lets crank it up in case they want to use the seats while driving."
It's too late but it will be appreciated if you have recovered the fault symptom or not.
In frankly speaking, I also got same problem, so I want to buy a new pump and test it before fitting in my car.
Did you find the test method how to activate the pump by mannually?
I also know +12V DC power line in the 4pin connector but I don't know how can I activate the pump by using of rest of 2 pin connector.
