service dept at MB
service dept at MB
Just left MB dealer and was told I couldn't pair my Samsung Galaxy s7 to my 2007 S550 phone system. Has anyone heard of this. Tech said MB system is not upgraded to the new phones.
Do you have a bluetooth adapter? If yes, which make? If MB, does the car see the phone in the list (assuming you properly activate the adapter and phone in the same time)? If yes, do you know the code needed to complete the pairing?
This is the MB bluetooth default adapter
MB bluetooth adapter
That is not true. I have a 2008 S550 and its "default" bluetooth adapter paired effortlessly with 2 Android phones: a Moto X and an Essential PH-1 (currently). The PH-1 was released on Oct 2017, so I'd consider it as a new phone.
Yes, to all of your questions. I have the adapter shown above and I have the 5-number code, which is under the adapter. Maybe just doing something simple wrong...thanks!
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Sorry, I am still a bit of a rookie here as I just got my S550 4 days ago.
Thanks for the help.
These are the steps to follow:
Step 1: Enter the vehicle in the driver’s position. Vehicle must be parked outside in a safe place
with the engine running. Be sure you have your approved wireless phone and your wireless
phone owner’s manual.You can not be speaking on the phone you are trying to pair.
Step 2: The Bluetooth Interface Module should be attached to the connector, located in the
center armrest.
Step 3: Locate the text “Bluetooth” towards the rear of the Bluetooth Interface Module. Push
down on this section of the module for 3 seconds. A blue lamp on the module will begin to blink.
Step 4: Pick up your wireless phone and set up your phone to pair to a Bluetooth device as per
your wireless phone owner’s manual. During this process your phone will ask you for a code, use
62872.
Attention 2007-2009 S-Class and CL-Class customers! 2 Bluetooth devices will appear as
found on your wireless phone. Be sure to select MB Phone System.
P.S. Make sure your phone's BT is enabled.
center armrest.
62872.
