Motor mounts/transmission mounts
another way is the detach the ac compressor to get to the engine mount. from the front
both ways you have to support the engine with some type of jack and a special wrench to get to the top nut.
My indy charge about $300 for labor.
however Tranny mount is very easy to do. so my indy did it included with the same billing.
I would like to hear other's opinion as to whether it is reasonable to replace Engine and Transmission mounts as a next step.
my vibration appears temperature sensitive ... lessens or goes away the more I drive.
they are pretty sophisticated engine mounts, not the usual chebbie stuff
secondary air injection fan motor runs first 30 seconds after start ... but I think mine vibrates longer than that
might be good to review this thread, including the service bulletin posted
https://mbworld.org/forums/s-class-w...d-failure.html
i don't know how to project mechanical lifespan but a visual inspection can reveal condition. Regardless, they don't last. Mine have been changed and all is silky smooth like new.
Not sure what my next move is, try to unstressed the mount as listed in the other thread?
supposedly what I’ve seen as mentioned before, if you get a cel with vibration it’s usually a misfire. Either that or it’s a coil or something not very hard to find since it will throw a code. But other than that the top 3 things it could be that makes the w221 vibrate is either bad spark plugs, maf sensor, or motor mounts
As for my vibration at Idle issue, I changed all the spark plugs and so far no more vibration!
I ordered a transmission mount... Should be here soon. Figured I would try the low hanging fruit first.
If that doesn't fix it, I'm going to need to get some quotes on engine mounts or carefully give them a shot myself. From what I understand, the motor mounts are pretty easy as long as you have the right tools and equipment. Should be no more than a 2-3 hours at an independent repair shop.
New gaskets
Old gasket, rubber is very hard and not soft any more --> air leak.
New gaskets
. Has anyone tried that btw
