My 2008 S550 command center went out
My name is Steve and I have a 2008 S550 4matic
My aux cord, I can't control the temperature for the heat and air, I can't cut off the heat or air in the back, I can't control anything from my steering wheel, my voice command doesn't work and my radio stays on when the car is off , is this a fuse and where is it located? Tbanks for your time and patients
Rear SAM is locked in the back seat behind the center hand rest in the hidden compartment
does the roof light comes on when driver door open?
under the drive seat there’s a can network see if water is in it.
you will need to move the seat all the way forward and lift the carpet
you don’t have to remove seat or carpet. Just bring it all the way forward
I was told if the left side inside the trunk gets wet it can cause things to blow. I always got a cooler in my trunk so water couldve gotten in that section. Is this true if so can I dry it out or do I have to replace what's in that corner?
no problems with dvd drive but it does shut off while I’m driving but not in the beginning.
