Synching Panoramic Sun Shades
Mine do not move together, but are controlled separately.
You can command an open or close with the diagnostic tool, and it will work -- so as you correctly observed, you know the motor is good. A defective switch would cause the symptom you describe. The "open" contacts are obviously good, but the "close" contacts may not be. If you poke around in XENTRY/DAS you will probably find an actuations page that will show you the state of the overhead console switches, so you can see if the state changes when you push the switch in each direction.
I would expect that there may also be a limit switch in each end of the shade travel... one to stop the motor when it's fully open, and one to stop the motor when it's fully closed. If the "shade fully closed" switch is stuck, that would also prevent the motor from closing the shade since it "thinks" the shade is already fully closed. In many cases (like power windows) there isn't a limit switch, but the controller senses the current drawn by the motor nd stops when that indicates the window is fully open or closed. I don't know what method the shades use, but I'm sure someone here does.
