Airmatic problem w221 320 4matic 2007
Old Mar 15, 2021 | 01:49 PM
milamg's Avatar
W221 S320 - W221 S65
I was driving on highway, and sudnly i got message on screen FAIL ( picture of lifting car).
Rear of the car lifted as higst possible and its stuck, wont go down. Can someone help me what that is?
Old Mar 15, 2021 | 02:10 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Level control switch in the rear attached to the axle is the likely problem due to breakage from corrosion.
Old Mar 15, 2021 | 02:13 PM
milamg's Avatar
so what should I do?
Old Mar 15, 2021 | 02:22 PM
EasyPhil's Avatar
Look under the car at the rear axle, if the rod is broken, replace the rod. 221 320 2589
Old Mar 16, 2021 | 10:36 AM
BOTUS's Avatar
S500
the weight of the linkage and or a bump will likely make that fall so it dumps all air and becomes undrivable
your failure mod is unusual... never drive when down it damages the airbag
Old Mar 17, 2021 | 10:27 AM
millamg's Avatar
w221
There is no rod ad rear axel. I checked.
Rear axl
Rear axl
Old Mar 17, 2021 | 10:55 AM
EasyPhil's Avatar
It's in the middle of the rear of the car attached to the rear sway bar, you have to be under the car with a flashlight and is not visible from the angle of the photos you have posted. Get all the way under the car or get it on a lift and you will see it.
Old Mar 17, 2021 | 11:42 AM
millamg's Avatar
w221
Originally Posted by EasyPhil
It's in the middle or the rear of the car attached to the rear sway bar, you have to be under the car with a flashlight and is not visible from the angle of the photos you have posted. Get all the way under the car or get it on a lift and you will see it.
This one ?
Old Mar 17, 2021 | 11:49 AM
BOTUS's Avatar
S500
its well hidden, from left, look in 18", in front of the rear wheel.... as per the last photo
its sits ABOVE the park brake module
Old Mar 17, 2021 | 11:58 AM
BOTUS's Avatar
S500
that looks like the bracket that usually snaps off is OK and the link rod just fell to bits on the sensor end...
you could just swap the link using the new ball and socket on the sensor end and pop the other plastic ball joint on to the bracket that's still on the anit-roll bar.
But double check its integrity if all four of the silly 2mm bits that locate the ball to the clamp are not fractured and the new socket moves nicely on the old ball you could get away with it... otherwise its super nasty. There is no way u can clip the clamp on the anit-roll bar in situ...
Old Mar 17, 2021 | 12:44 PM
EasyPhil's Avatar
Originally Posted by millamg
This one ?
Clearly broken.
Old Mar 17, 2021 | 12:57 PM
EasyPhil's Avatar
When you attempt to fix this not using a lift the height of the car in the rear will go down as you remove the rod and replace it with a new one and then re-attach it. Be careful, you could get crushed under the car.
Old Mar 17, 2021 | 01:51 PM
milamg's Avatar
how many rods are in rear axle ? one or two?
Old Mar 18, 2021 | 02:55 PM
BOTUS's Avatar
S500
one
the fronts do the side to side (and the front level), 3 in total
Old Apr 9, 2021 | 09:25 AM
milamg's Avatar
Just replaced the ROD and nothing happend, Turned ON the car, Nothing. When i hold the LIFT UP butten. The car lowerd rear. All the way down.cant drive the car , the tires will scratch body. WHAT TO DO?
Old Apr 9, 2021 | 09:32 AM
milamg's Avatar
Old Apr 9, 2021 | 11:36 AM
EasyPhil's Avatar
The orientation of the rod is probably incorrect. In relationship to the sway bar that the clamp is on and the switch it is connected to, the rod should be angled as such: /
Look at your photo that shows the rod broken, it should have the same orientation but connected to the switch.
Old Apr 9, 2021 | 11:44 AM
BOTUS's Avatar
S500
did the fuse pop when the rod fell off.... and its let the air out to drop the height?
be careful working on it like that.... I expect you haven't connected it right... I guess EasyPhil's point could be correct.... with the wheel off and along screwdriver you can reach and get it to lift (if its working)
Old Apr 9, 2021 | 11:51 AM
EasyPhil's Avatar
If the orientation of the rod is incorrect, he will have to disconnect it from the switch to correct it.
Old Apr 9, 2021 | 02:01 PM
BOTUS's Avatar
S500
yep, should be able to pop off the end get it up, then, with a jack in place get it work so up is up, not down
Old Apr 9, 2021 | 03:05 PM
milamg's Avatar
OK. I had it down, I'll try to get it up as the picture ( off broken ROD). Dont worry, I have the car jacked up. So im safe under.
Old Apr 10, 2021 | 06:07 AM
milamg's Avatar
I just replaced the orientation as it should be. The car did get up a litte bit , and the lift up butten work as well. But the car is still low at rear.
Old Apr 10, 2021 | 08:30 AM
BOTUS's Avatar
S500
if the orig sensor is seized (normal) and someone changes software to fix it then when you replace the ride height can be wrong
it may settle a bit as it works out life....
or it might pop the fuse (it very common) when working it hard
its possible but shouldn't happen (there's a flat for the bracket to sit in, to keep its location on the anti-roll bar) that things are not seated where they should be, with the extra fun u had might be work checking the integrity of the rusty bracket. When a ball is seized it puts all the movement into the bracket, which then fails and the thing usually drops on its ****
