Mystery coolant leak
so I finally thought I had fixed everything to do with the coolant /oil leak issue when I fixed the oil cooler gasket but I guess not. I can’t for the life of me find the leak. The random add coolant message comes on the cluster. The car has 170k miles. There is absolutely no noticeable puddles on the ground when parked..
Also check your engine oil for signs of coolant. Do you have rough idle, or coolant (sweet) smell from the exhaust?
This one seems like it would have an adapter that fits: https://www.mishimoto.com/mishimoto-...hoCGc0QAvD_BwE
Internal leak such as mentioned in Konig's document, along with 170k mi, for me anyway, would translate to an engine swap. Easier just to throw a new motor in it. Are you M272 or M278?
I have an update that I am pretty excited to tell everyone. I took the advice on this thread and used dye to locate the coolant leak. I used a dye and uv flashlight. The coolant expansion tank is the source of the leak. The tank has a hairline crack. The lime green color you see in the picture is the coolant leaking. I went with an aftermarket coolant expansion tank. I can’t really complain too much as the car has 170k miles. These things are bound to happen.
