Hi family, I'm asking for advice on a COMAND update. thanks in advance greetings to
Old Sep 18, 2023 | 04:41 AM
BOTUS's Avatar
S500
oh dear - FYI in settings - time and date - you will find the year info matching what you see in that ENG menus.... - whilst you can appear to adjust, it will not retain the change - the auto time keeping will swap it back as you come out of the time and date settings menu (as soon as the car has visibility of any satellites). The clock fix fits on a CD as its a severely cut down version of the entire update DVD.. You may as well make the disc and give it a go - link for the file below - Note, computers aren't as stupid as people give them credit - it will try to get the data and if OK write it to the hard-drive, otherwise it will say its a no go - its less than 10 mins start to finish - if that fails, then you know you need to do something else to get further....
there are different versions of CDs / DVDs reflective layers that contain the software info - on every disc made is an inner ring that contains info about the disc, its material and how it was written - the first thing any drive does is interrogate the disc to work out if it knows what to do with it.... if the hand shake goes well, they go on to try and read the important info (AKA software / musics / video etc.)
this is what you want to see happen
make this disc - its a later better file
https://mbworld.org/forums/s-class-w221/760659-promising-long-term-fix-ntg-3-0-date-time-issues-11.html#post8468441
