W221 Suspension Metal clunking noise
Old Apr 11, 2022 | 06:10 PM
alberson's Avatar
w221
Hey! I am new to the form, so please let me know if I am doing anything incorrectly!
I been having very loud metal clunking suspension noise from front right suspension.
The air strut is new from Aronnt.
I inspected all rubber joint, and they were in good shape, no tears etc.
I also lubricated the sway bar and all rubber joint. But the problem still persist.
Squeezing sound at low speed or braking.
Metal clicking sound right after lock the car.
Running out of way to figure it out. Really hope someone could point out the problem!
2013 Mercedes s350 4matic bluetc
The noise could be hear from youtube:
Old Apr 11, 2022 | 08:02 PM
COUPCONNOISSEUR's Avatar
2010 CL550
I had this same noise, I believe replacing the lower front spring arms corrected it.
Old Apr 11, 2022 | 08:24 PM
alberson's Avatar
w221
thanks for the information! I will look into it.
Old Apr 11, 2022 | 09:32 PM
Senecat's Avatar
1983 Nissan Shltbox
You're standing right there in front of it. Stick your head in there and figure out where it's coming from. What am I missing here?
Old Apr 11, 2022 | 09:45 PM
alberson's Avatar
w221
i absolutely did my research before I posted.
I was trying to see if anyone had the same noise and successfully repaired it.
oh. But thanks for the help?
Old Apr 12, 2022 | 04:11 PM
tbilisi79's Avatar
Did this happen after installing Arnott springs?
I had similar noises in My mark VIII, twice replaced with Arnott. I dont like their products and would never install it on a MB.
Air bladder anyone can change, the shock part gets more involving and I prefer quality parts. Not sure where Arnott gets the strut part from or how they rebuild them.
Old Apr 14, 2022 | 05:44 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
I have the same creaking sound on my car..
Old Apr 15, 2022 | 05:50 AM
Minh's Avatar
S350 2008
The noise is from sway bar
Old Apr 17, 2022 | 08:12 PM
Arrie's Avatar
The noise could be hear from youtube: https://youtube.com/shorts/ggoV2fsnUfc?feature=share
I had this exact problem and the reason for it is worn and dry REARWARD lower control arm ball joint(s).
if you inspect the ball joints you will have to disconnect one of the lower arms from the hub. You cannot check them for wear as the FORWARD one of the lower arms is probably in good shape and will not let you “wiggle” the hub by hand. I went around this first but then disconnected the rearward arm on the right side and voila, the ball joint was badly worn and dry. Dry joint is what makes the noise when you park and car lowers itself.
After replacing the right side arm I also replaced the left side. Bought both arms fro FCP Euro. Did the job myself.
I guarantee your problem is the rearward load carrying lower control arm ball joint. No question about it.
