Spark plug replacement; plug boots necessary?
Old Apr 18, 2022 | 07:06 PM
RichDMB's Avatar
2008 S550
Replacing the boots doubles the cost, but is it necessary or at least strongly recommended? Not trying to cheap out here, but don't want to **** away money when it's not necessary. Who knows what costly repair is ahead!!
And what are the recommended plugs? Rockauto has NGK95983's for $3.84 each!
Old Apr 18, 2022 | 10:32 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
No need to replace the boots. But depending on the mileage, specially the V8's, can benefit from replacing coils. Now, as long as you don't have any misfire or slight vibration, you should be good by just replacing the spark plugs.
Old Apr 19, 2022 | 08:05 AM
RichDMB's Avatar
2008 S550
MBENZTECH, which spark plugs do you recommend? Both FCPEuro and Rockauto list several for the 2008 S550.
Old Apr 21, 2022 | 02:25 AM
MBENZTECH's Avatar
We use genuine Mercedes Benz spark plugs in the shop. I had a few aftermarket come back misfiring. For your engine(M273) you can get away by using the Bosch OE finewire platinum. Part number YR7MPP33.
Old Apr 21, 2022 | 08:15 AM
RichDMB's Avatar
2008 S550
Great, that's what I ended up ordering last night. What about applying anti seize gel to the plugs? I read somewhere that Mercedes recommends NOT applying it.
Old Apr 22, 2022 | 02:10 AM
MBENZTECH's Avatar
Do not apply anti seize.
Old Apr 22, 2022 | 07:09 AM
chassis's Avatar
2017 GLE350 4MATIC
Agree no anti seize, it changes the torque-tension relationship.
I would change the boots. They are rubber and don’t last forever. W221 is an old car now.
Old Apr 22, 2022 | 05:28 PM
lkchris's Avatar
'10 CL550, '12 GL550
https://nemigaparts.com/cat_spares/e...asis=21638665V
Workshop Information System (WIS) does specify a grease to put on inside of boot to facilitate future coil removal.
Correct sparkplugs for your vehicle are
NGK PLKR 7A
or
Bosch Y 7 MPP33
Bosch YR7MPP33 are American aftermarket items not appropriate for your car. The R means resistor and resistor plugs are not specified.
