Trouble at start - S500 M273
Old Apr 18, 2022 | 10:59 PM
JackInJapan's Avatar
S500
Hello,
I have trouble starting my car. When the engine start not problem. Idle is perfect and I can drive hundreds of KM (700km) without any problem. But when I stop the engine sometimes it's impossible to restart. I have to wait 20 minutes and the engine start and works perfectly again.
I use a carsoft 1.0 to get some errors code. First I got a P0336 crankshaft sensor error
Q : is it possible to have crankshaft sensor error even after start the engine works perfectly ?
Finally that error stop to show up
Then I decided to change all sparks and coil : no change
Then the P0410 came.
I discover that the secondary pump was faulty : I change it
The problem still occurs
If anyone have an idea to help please let me know.
Big thanks in advance
Jack
Old Apr 19, 2022 | 01:42 AM
Minh's Avatar
S350 2008
Crank shaft sensors might be a root cause because it might not working properly when engine warm up. this sensor is located in the top rear left of the engine.
Old Apr 19, 2022 | 03:25 AM
S500
Thank you very much for your answer.
Is the sensor used only during the starting phase ?
or/and active after the engine has started ? If so I wonder why I can drive hundreds of KM without any problem
Big big thanks
Jack
Old Apr 19, 2022 | 04:17 AM
Minh's Avatar
S350 2008
Signal from crank shaft sensor is required all time when engine running but when it intermittent failure then it hard for start when engine warm up.
Old Apr 19, 2022 | 04:20 AM
S500
Thanks again !!!!
When the weather is hot I also have some problems to start, then I will change the sensor and see what will happened.
Thank you very much
Jack
Old Apr 19, 2022 | 08:22 AM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
It is definitely the crankshaft position sensor. Typically happens when you drive a while, stop for fuel, fill up, and then it won't restart. It is not expensive.
Old Apr 21, 2022 | 07:33 AM
Senecat's Avatar
1983 Nissan Shltbox
Crank sensor.
Old May 27, 2022 | 01:46 AM
S500
Hello Everyone,
I change the crank sensor, but the problem still occur. Only at start. I also check every Relay and Fuse.
After starting the engine work very well at idle and drive. No stall no problem at all.
I was thinking of the fuel pump but how can the engine work perfectly after start if the pump is broken.
It's a NIGHTMARE
Thanks anyway
Jack
Old May 27, 2022 | 04:39 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Probably irrelevant and laughable, but I had a Porsche many years ago with the same problem. It was a fuel check valve that was bad.
Old May 27, 2022 | 04:45 AM
S500
Hello Nath_h
At this point nothing can be more ridiculous than this situation :-)
Thank you anyway, I will investigate that as well.
Jack
Old May 27, 2022 | 05:50 AM
Senecat's Avatar
1983 Nissan Shltbox
Could be cam sensor/s.
Old May 27, 2022 | 06:23 AM
S500
Hello Senecat,
Thank you for your help.
Yes maybe. But again when the car start NO PROBLEM, I can drive with no limit. if the cam shaft are faulty is it possible to drive..
It's already 2 month since the beginning of that problem. Little bit fade up...... I should give up that car :-(
Thank you to every one who helped me
​​​​​​​Jack
Old May 27, 2022 | 07:26 PM
Senecat's Avatar
1983 Nissan Shltbox
Could be fuel, who knows. Your problem seems to be evolving. Pull codes, check values, start running down the diagnostic and repair flow charts.
Air, fuel, spark.
Old May 8, 2026 | 10:27 AM
moazzemzaidi's Avatar
S500 W221 | 55' Bel Air | 60' Bug
Originally Posted by JackInJapan
Hello Senecat,
​​​​​​​Jack
Following up on this
What became of the problem
