Help Inside Wear on Tire
are you running the standard wheels and tyres for your car and the suspension its at its standard ride height ?
if you have the wrong wheels and or fiddled with the suspension height - I'm not surprised you have issues - but that is so far off the edge I wonder if its hitting a suspension arm or ARB when on steering lock
heavy wear on the edge can be suspension geometry out of sorts - like too much camber or toe - but to break up so far off the side seems strange for that
what tyre pressures are you running?
what tyre pressures are you running?[/QUOTE
i am running standard wheels and tires. Suspension height hasn’t been adjusted. Car is stock.
im taking it in to my mechanic on Friday, he says it could be multiple things and obviously would have to take a look at it to get a better idea..
i was just checking here if anyone else may have experienced something like this before.
either side of that split there is FAR less wear - check visible snipes in line with the t of continental ?????
you don't need camber bolts there is a better way with JUST the camber washers... if you have the car stock it shouldn't present that much of an issue
Mercedes makes a bolt kit with longer adjustment to combat this issue without replacing all of the suspension components.
The dealership installed this kit, and my problem was solved. Alignment was able to be brought into spec.
Tom
This is a picture of the driver side tire taken on the same day
