Front Lower Control Arm Replacement Help
Old 07-04-2022, 10:41 AM
s550hollywood's Avatar
2013 s550
I think I finally feel confident to replace the front lower control arm with ball joint on my 2013 Mercedes S550 but I cannot find any info on how to deflate the air strut. Has anyone ever done this before?
I don't have the fancy software and laptop so is there another way to get the air out of it.
Old 07-04-2022, 11:48 AM
COUPCONNOISSEUR's Avatar
2010 CL550
you’re not really supposed to deflate them without star but I’ve done it this way several times and never had a problem.
After you have the car jacked up and not running, SLOWLY loosen the fitting at the top of the strut until you hear air escaping, when it stops hissing you can fully disconnect the line and have a deflated air strut. Also, before deflating take a measurement of current ride height(distance from the center of the wheel hub to the edge of the wheel well, usually around 15-16”) it is at that distance the vehicle needs to be lowered to before inflating them again.
Old 07-04-2022, 11:50 AM
BOTUS's Avatar
S500
you don't do anything with the air strut (obviously get the weight off that corner first)
you'll have far more fun getting the inner bolt out as the rack is in the way - and first stop is to check if the geometry is outside spec - and use the adjustment bolts to get you the choice to set it in spec when u add the new arms
don't change the bolt - utter waste of time just buy 2 washers available separately and remove the offending bit on the subframe that shouldn't be be there - when building a car with accurate geometry (2 washers per side - but only one side is built wrong)
Old 07-04-2022, 12:08 PM
2013 s550
WOW I have no idea what you're talking about and it sounds complex. Maybe dealership is the best solution for replacing this. The dealership replaced the other side last year for $500 labor and $500 parts for $1000 total. I did notice they sell the part on their website for $264 so I guess they double the price on parts when you take it in.
Old 07-04-2022, 02:57 PM
2013 s550
Not sure what the rack is you refer to, I was under it looking to see if I can do this and the only thing I saw in the way is the plastic road shield as its blocking the bolt where the arm connects to body.
If you can offer a more clear understanding of what your diagram refers to I'd like to do this job myself but I'm not understanding what you're saying here.
Old 07-04-2022, 10:36 PM
Arrie's Avatar
Nothing fancy about this job other than the bolt under the car is very tight and obviously also needs to be tightened very tight. I changed the load bearing control arms on both sides and the only obstacle was the plastic shield under the engine. I did not bother getting under the car, so I ended up breaking a small part of the plastic shield where the bolt needs to come out/go in. Big deal...
A thing to know is to measure the center of the hub distance to the fender edge when car is sitting at it's normal height. Then before tightening the bolt under the car set this hub height first. This way the rubber in the end of the arm does not get twisted too much that can cayuse it to break actually.
Old 07-05-2022, 10:36 AM
EasyPhil's Avatar
2007 S550 4Matic
Remove the plastic shields, it makes the job easier.
You need jack stands and ramps for this job. Jack stands for the initial removing of the control arm and ramps so that the wheels are bearing the weight of the vehicle before tightening the control arm to the body of the vehicle.
Old 07-05-2022, 10:44 AM
EasyPhil's Avatar
2007 S550 4Matic
If you have a 4matic ignore what BOTUS posted, you have a regular washer.
Old 07-05-2022, 11:09 AM
BOTUS's Avatar
S500
there are two lower arms
aluminium ones part 120 and the front bush falls to bits (you can buy part 125 but pressing them in is a nightmare and you need to pop the ball joint without screwing the boot)
and a track control arms made of steel - the inner bolt part 90 for the steel arm part 70 won't come out as the steering rack is in the way - you can with a special tool remove the arm from the rack and leave the rake in place
part 100 can be replaced for the adjustment washers - available separately A 20 233 303 76 - $1.31
https://nemigaparts.com/cat_spares/e...71/63w/33/030/
Old 07-05-2022, 11:20 AM
BOTUS's Avatar
S500
4matic lists the washers to get the camber right ?
https://nemigaparts.com/cat_spares/e...86/63v/33/045/
Old 07-05-2022, 11:28 AM
2013 s550
Mine on my 2013 S550 which is not a 4Matic looks like this. This pic is upside down and the air shock sits on the middle section.
Old 07-05-2022, 11:32 AM
EasyPhil's Avatar
2007 S550 4Matic
No, the bushing doesn't have the internals like other models. Meaning the hole in the bushing doesn't accommodate different orientations. I recently replaced bushings in the Thrust Arm, they have a hole like this: O Not like this: (__).
Old 07-05-2022, 11:34 AM
EasyPhil's Avatar
2007 S550 4Matic
Thrust arm bushing would have an adjustable hole. This control arm bushing has a standard round hole.
Old 07-05-2022, 11:41 AM
EasyPhil's Avatar
2007 S550 4Matic
Replacing the bushings is fairly easy if you have the right tool, takes about 15 minutes if that. Part 70, the lower control arm, can be removed easily, you just need a ball joint separator kit to take of the ball joint and to push the shock ball joint out of the arm. I did this about a month ago.
Old 07-05-2022, 12:57 PM
BOTUS's Avatar
S500
EasyPhil the bush is just a bush - you get the adjustment by just doing the bolt up in a different part of the subframe
the white bit is air and the black is the subframe ....
The drivers side needs adjusting on all right hand drive cars - forget which way - so you land on manu spec as you try to get the car so it drives in a straight line -
IF you know the arm needs to be effectively longer, you grind the triangle out on the outer side, letting the real bolt sit further out towards the road wheel and fill the gap behind with the special washers and retain the better stronger bolt (that's how the good dealers do it) - its a one off correction - not a wandering entity through the cars life - the other idea of the dodgy weak bolt is to allow the tyre fitters to know you have adjustment - BUT its game over when they attack it with an air gun and the bolt tears the triangle off the subframe anyway
Old 07-05-2022, 01:28 PM
EasyPhil's Avatar
2007 S550 4Matic
The bushing for the control arm or thrust arm for my 4matic doesn't have that spacing, it's a round hole not an elongated ellipse like hole that you are showing.
Old 07-05-2022, 01:59 PM
BOTUS's Avatar
S500
the guy originally was asking about track control arms (and that's the adjustment I'm talking about) - they sell bolts to fiddle the castor control arms but its recco'd not to touch as likely will screw all the rest up
naming in motoring is generally rubbish
lower control arm in what direction ?
track control = width
castor control = nasty McPherson strut inferior suspension control under heavy braking
anti-roll bar = what it does (not what girls evening dresses do)
Old 07-05-2022, 03:42 PM
2013 s550
Sounds like the dealer will get my business for this replacement when it starts to give me trouble. Right now just the rubber above where I'm pointing my finger in the pic is cracked but the car still drives just fine. Upon looking underneath the car last week, it appeared like a simple "unbolt it" and "replace it" type job but I guess looks are deceiving as you guys make it sound pretty technical which will earn the dealer some business. This car is apparently nothing like the deuce and half's and hummers and tanks I worked on in the army. I have some Jackpoint Jack Stands on the way and will have to decide whether I want to attempt this job or not myself. It looked to me like it was just two bolts and the pressure of the air shock I was dealing with which is why I always ask on these forums. Its always that small part I may not know that can cause problems ultimately requiring a tow truck taking my mistakes to the dealer to solve after all.
Old 07-05-2022, 05:00 PM
EasyPhil's Avatar
2007 S550 4Matic
This is a simple job with the right tools and a small amount of mechanical aptitude. You have 3 nuts to undo and 2 joints to separate.
Old 07-05-2022, 05:25 PM
MowgliCSM's Avatar
07 S550, 99 Q45t, 89 Mirage Turbo
Due to having to tighten the inner bolt while the suspension is loaded, after I am done changing the control arm, I will place jack stands under both front knuckles and lower the car on to them. I will not drop it all the way at the beginning just enough that the weight is on the jack stand, then I will reattach the air line, start the car and allow pressure to rebuild in the strut. As it is pressurizing, I will slowly lower the rest of the way until the struts are fully inflated and the entire weight is upon the jack stands. At that point I have tons of room to properly torque the inner bolt. Then jack the car up, remove the jack stands and put the wheels back on.
Old 07-06-2022, 04:57 PM
2010 CL550
Old 07-06-2022, 10:48 PM
EasyPhil's Avatar
2007 S550 4Matic
Just invest in and use a set of ramps.
Old 07-06-2022, 11:11 PM
2013 s550
This says its for 4Matic. I have a 2013 S550 Base model, its not 4Matic.
Old 07-07-2022, 08:26 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I've never done anything superstitious with the air suspension on either car. I hear crazy stories about air bags blowing out. People say stuff like "don't open the door with the car in the air" and stuff and that always seemed ridiculous to me. I've had these cars running in the air as you have to do sometimes and nothing blows out....
I know some Range Rovers and stuff have a special jack mode to disable the system but these cars don't have those modes and as far as I can tell, don't need them. It may have to do with the extended suspension travel in truck applications vs car.
Old 07-07-2022, 09:24 AM
2013 s550
I used to have a 2007 Lincoln Town Car that had a switch in the trunk you had to turn off before lifting the wheels off the ground. It was said to me if you didn't turn that switch off that the air bag suspension in the rear would blow up and pop. I've always wondered about that with my 2013 S550. I have not lifted the wheels off the ground with this car yet but have not heard of any switch to turn off either. There doesn't seem to be any kind of switch in the trunk. Its reasons like that I typically take this car to the dealership because in this case, its what you don't know that can hurt you financially if you screw something up.
Can anyone confirm that there is no harm in raising the wheels of the 2013 S550 off the ground without disengaging the air shocks?
Quick Reply: Front Lower Control Arm Replacement Help
