Is a partial facelift possible?
I'm a new guy. I don't have an MB yet, but the short list has gotten really short - 2011-2012 E350 Cdi or 2009-2010 S350 CDi.
One E350 CDi is a 4Matic Kombi with air suspension, the other is the sedan with roughly the same equipment.
The S350 L Cdi I'm considering is not 4Matic. It has all the facelift options - including the correct facelift tail lights - EXCEPT the facelift style LED strip lights at the lower front corners. It has the same semi-triangular fog lights (or driving lights?) as the pre-facelift cars. Is this correct? Did some facelift cars have pre-facelift front ends? This one is registered as built in 2009.
Thanks,
Glenn
the obvious external points are very different door mirrors (squared off) the older one's look nicer, the strange (but you get used to them) and they look less dated all red tail lights (you don't want budget Chinese knockoffs) and as you say the LED strips on the headlights - not yellow dim 5w side lights. Then INSIDE fold down the flap under the heater bottoms and look to see if there is a removable caddy to pull out the hardrive on the comand unit
if its a facelift you get in europe 7 digit postcode entry for correct input of addresses in the UK... for some silly reason everywhere else in the world you need to add the road and the location along the road - different menus on the comand unit (blue background) , and petrol stations show by brand etc,
if you find RCA phone connectors in the glove lox its an old car
Glenn
bumpers did change between trim levels - these things eat money like no other car....
Yeah, that eating money thing keeps me leaning toward the E350 CDi's.
Thanks,
Glenn
also need to realise Germans make cars that are fundamentally competent but have been designed to last for a much shorter timeline - by 1990 the idea an abused merc lasted 30 years, changed to a pampered one still looks good 10 years in, but you better enjoy the spares counter and DIY every weekend
last 15 years - korean and japanse always in the top 20%, anything german always in the bottom 20% for reliability
Yeah, I've had Nissan/Infiniti for the past 20 or so years. Can't beat Japanese for quality & reliability. Or Chevy GMT400 trucks, either. Still have one long term. Over here the roads are dominated by the Germans - VAG mostly with BMW/Merc making up the rest and a smattering of French to stay far, far away from. Everything is diesel.
The VAG 3.0 TDi all need timing chains replaced (at the back of the engines), the MB 200/220/250 CDi all need timing chains replaced (also at the back of the engines, but can be done without engine removal if early enough and guides aren't beaten up). The MB 3.0 CDi (OM642) - the newer ones (2011-2012) usually don't need timing chains and the 2012 sometimes have the updated oil cooler seals. So, with that engine, it can usually stay in the car. BMW big diesels don't seem to have many problems, but the cars themselves, particularly the 7's, don't seem to be any better than the W221, maybe worse.
There are some Infiniti's here, but they use Renault diesels. The 5.0 gas V8's also need timing chain replacement, ugly job.
Thanks,
Glenn
early 4x4 w221 came with a dodgy bearing in the transfer case
early v8s came with chocolate cam sprocket
early v6s came with chocolate balancer sprockets
v8 have semi chocolate coil packs
v12 come with pre melted mortgage you house coil packs and a chocolate gearbox that needs rebuilding every-time the throttle is opened more then 6%
all the current models have chocolate cam chains
So, define early, if you would. I would say pre-2009 for most things.
I think most of your list pertains to the gasoline engines. That said, I do know about timing chain/tensioner/guide problems with the early OM642. BUT, I thought that had been corrected by 2009-2010. Or not? Certainly there isn't any routine timing chain replacements around here now as compared with on the 2.1 diesel (OM651?) or VW 3.0 TDi.
All told, it seems my initial wariness for the W221 is justified. It's a shame because I would appreciate the additional space of the bigger car. I also wasn't sure about if the E Class would be big enough to suit us. It seemed somehow small when we sat in it. I did a comparison with our old 2003 Maxima last night and discovered that while the headroom is an inch lower, the rest of the interior parameters are equal or an inch or three larger than the Maxima. We found that was big enough in that neither of us ever remarked anything about it being small.
