W221 S500 M273 noise
Old May 23, 2023 | 07:00 AM
JarppaFIN's Avatar
MB S500L 2006 (W221)
I have a 2006 500S(S550) M273 on the engine. Mileage 360,000km. It runs just fine, the power is there and the consumption is not so bad now... But
When accelerating, especially if you're going uphill at around 3000rms, you can hear a wonderful knocking. The sound can also be heard
standing still, but a much softer sound. As if it were coming from below. When the engine is cold, there is almost no sound.
Replaced, all roller, alternator, water pump, multi-groove and it doesn't seem like it's part of the auxiliary equipment, although I doubt the ABC pump a bit.
What could be the reason?
Old May 23, 2023 | 07:36 AM
BOTUS's Avatar
S500
engine mounts fail - see if all the gunge has oozed out
Old May 23, 2023 | 07:40 AM
JarppaFIN's Avatar
Engine support and transmission support replaced.
Old May 23, 2023 | 02:48 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
Any diagnostic codes? It sounds to me like a bad anti-knock sensor. Are you using high octane fuel? Check codes and keep us posted.
Old May 23, 2023 | 03:08 PM
JarppaFIN's Avatar
Hi, I use E95/98 octain dosent care. No errors for star.
Old May 30, 2023 | 07:40 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
check sway bar bushings if theres a gap between the bushing and sway bar. they usually squeak but you can get a knocking sound from that too if its particularly bad
Old May 31, 2023 | 11:34 AM
Arrie's Avatar
My 2013 had a knocking sound under heavy acceleration going uphill and it stopper after I replaced the rearward load bearing lower control arms. The ball joints were worn out.
I still don't know how this would cause the sound under acceleration but it did.
Old Jun 2, 2023 | 04:22 AM
SPONSOR
yeah i can't tell you whats going on til I see under the car, could be driveshaft couplers, suspension, strut mounts, BJ's, etc. congratulations on a long life with that car btw
