Electronic undervoltage issues/bricking
the cars eat 37 amps with the key turned on engine off - so if you leave the key on to listen to the radio it will kill any battery dead in less than an hour - as the cars age the way it burns electricity seems to increase and a new battery will get funny in 20 minutes
even taking the key out and never leaving a door open and just driving the car - if its not used for 2 weeks 50% of the batteries grunt will have gone walkabout - leave it three weeks and it will throw error messages to itself - but on dual battery cars it will start
all cars are heading this way - but the 221 seems to have the most need to waste volts
bricked means it has become as useful as a brick - as in NOTHING can get it to function ever again
if you can charge it, it was just low volts ... keep doing it on a long term basis and you'll head towards damaging the battery and shortening it life span - that's not bricked
sounds more like a module is staying awake
Keep us posted and good luck!
I'd be partial to buying a new part and if it doesn't resolve your issues; I would send it right back. Of course, it is so easy for me to spend your money and time. But I do think your alternator is on the way out.
https://www.fcpeuro.com/products/mer...rnator-al0864x
Keep us posted.
Keep us posted.
You could have both a failing alternator and a parasitic drain. In fact, a bad enough drain for long enough could actually kill an alternator. I had an old Plymouth and the floor mounted bright lights button grounded out to the unibody frame and caused me to kill three batteries and three alternators before they discovered the problem. And that was when a battery was $39 and an alternator was $100.
Keep us posted on the outcome.
can't we get into the service menu and check voltage like in the W212?
New battery is fine, obviously, but the alternator is smart, so you won't get a 14.5V constant charging sine wave. To do that, you have to disconnect the LIN line plugged into the alt. There is an extensive thread on this in the 212 section.
Point is, charging voltage will vary based on ECU logic.
For parasitic draw I use this Power Probe unit, saved hours, spendy but worth it IMO.
If you can find the parasitic draw and it turns out to be a component stuck awake, you might avoid that alternator replacement. I would also comment that a 15 year old alternator is probably due and you have a warranty. I'd go for it anyway. I know; it is so easy for me to spend your money.
