Who sells drilled rear brake rotors?
these cars do at least 155mph and the manu designed the braking system to allow you to stand on the brakes and safely stop
had they wanted to get you in to a massive crash with severe rear end instability, followed by the back overtaking the front and causing a 10 car pile up they would have fitted silly brakes at the back so it could do this easily.....
so you like the looks, but now everyone's else's life it at a higher risk than it was ??? under full on braking it takes very little modification to cause instability from the rear anywhere above 65mph
Car Modification Laws in Germany, car modifications are subject to the Straßenverkehrszulassungsordnung (StVZO) regulations, and vehicles must adhere to the Technische Prüfstelle (TÜV) standards
Motorists in Germany and Austria can only fit TUV-approved parts to their cars - the vehicle must remain roadworthy and operationally safe. After the conversion, the driving behaviour of the vehicle must not exhibit any critical conditions under normal operating conditions. This must be proven by an approval of the vehicle manufacturer or his authorised representative or by an expert opinion of a test centre, regarding all components with which the vehicle was converted. Under this condition, an entry is then made in the approval document (type certificate, individual approval notice or CoC document) at the office of the competent provincial government.
No one is doing 155 here lol We are just looking to match the fronts since it kind of look stupid that the fronts are drilled but tue rears are not. It is pure cosmetic and has none to do with performance 🙂
If drilled rear rotors definitely cause a heavy rear bias (they won't), then I could make the argument that you MUST run factory Mercedes brake pads and factory Mercedes everything because, who knows, it might just perform a little differently and cause a safety issue! Maybe I shouldn't be allowed to work on my own car, while we're at it. Obviously I don't believe any of that, and neither do you.
They make good rotors. That is where I bought my cross drilled rotors for the front and back of my 07 w221. Just make sure you use ceramic pads to keep the brake dust at a minimum. I use the Hawk street performance ceramic pads.
Two out of the discussions: Why MB does not even have a part number for those rotors? MB has made some iconic cars, so I assume they also have some auto-designers and consider the look and not only functionality. Perhaps we are better designers in both: looks and engineering.
On the "maybe we should not be allowed to work on these cars?" Perhaps is that why some parts come with this symbol. Either reminding to use a wrench and hat or that ONLY for certified mechanics (supposedly that implies knowing what they are doing).
now re this question - You missed the question I was asking - as there are three sets of brakes fitted on the w221 - what I asked was on the link you gave what are the current brakes fitted on the car ?
as I can't see their site offering replacement disc for cars that come with vented rears, it would concern me - if they don't make it clear there are multiple choices what else don't they know ?
had they wanted to get you in to a massive crash with severe rear-end instability, followed by the back overtaking the front and causing a 10-car pile up they would have fitted silly brakes at the back so it could do this easily.....
OP will be just fine. Full disclosure I am planning on doing the same thing. I need new wheels and eventually will have to change my rear brakes, which seem to last forever on the W221.
these cars were meant to be driven like a mad man on autobahns where a lot of those roads remain unlimited - if you go to Germany its normal to find many drivers on their gentle commute to work doing 120mph - and I've been in E class Taxis where the guy was doing 145mph... once wound up these cars transform from lumbering semi-s that don't really make sense - and start to behave more like sports coupe's - and really come in to their own with the needle the other side of 130mph - everything starts to make sense the whole engine performance curve, the gear ratios, the steering and the handling come together in ways that they can't even contemplate below 90 mph...
so if you're not trying to get the other side of 120mph you've bought the wrong car ! its why Jags are a much better option in the USA
I know for my Porsche Boxster they produce the standard not drilled and also offer drilled.
Last I looked at their website, they made a big deal regarding upgrading to drilled.
