Bent Wheels
Anyone with experience in wheels? Are all MB OEM wheels refurbished also? If my old OEM bent wheel can really be refurbished, is it better than new?
The plan is to also replace the front passenger wheel after I determine whether the rear one works out. I did find a discounted MB front wheel 19 inch X 8.5 inch for $550 plus $150 core charge on the MB Parts web site. That may be the solution to the front.
I suppose the real solution is not to clip the curb and not to find the potholes but I haven't succeeded yet.
All advice appreciated.
they will re harden with time - if you can wait 3 years between driving they'll sort themselves out
mate with a CL had his 19" wheels done and they are now all much worse
words on heat treating https://thermalprocessing.com/the-he...-introduction/
While I don’t know if they’re perfect, they balanced out perfectly, and are round enough that 18” 40-series tires roll smoothly, with no shimmy.
Without any paint needed, was only $125/wheel.
I had the "New" OEM (probably refurbished) wheel from i1parts on Ebay mounted and balanced. It was very straight and better than the old one. Transferred the sensor and the tire, balanced it, and the car runs much smoother at 65 mph. I still need the front wheel replaced and if the price is good, i1parts says he will have one in two weeks. I will post results after that.
I kept the old 9.5 X 19 inch rear wheel and plan to have a local shop refurbish it. Now that I have an extra wheel, doing a refurbish is so much easier. Drop it off, and run.
