System malfunction/airmatic/ leaning to the left
I have a 2010 S550 with 80k miles on it. I bought it used and knew there would be a few problems here and there. The other day i was driving it and at a red light i tried to raise the airmatic suspension a bit. As i drove on i heard my compressor cycling very frequently. Then I saw a system malfunction light on the dash and it stopped. I noticed when i came out in the morning the front left wheel well was almost laying on my tire. I have a feeling that is a rupture in the strut and I plan on replacing it myself.
I came outside this morning and the gap on both right side wheel wells is huge but on the left side it's minimal. The whole car leans to the left even after the compressor cycles several times and even after driving it aggressively in a round about, it still is leaning really badly. I also noticed that my compressor sounds really weak like it is bad. I have a few questions
1. do I likely have a bad driver's side front strut? Can I shoot air into it directly with a compressor and a blow gun to isolate and inspect it with soapy water?
2. Does it sound lIke i have a bad compressor and would that cause the left side to under inflate?
3. Will I need to have a recalibration done to my airmatic system?
4. Does anyone have any suggestions of things that I can check and or do to.fix the lean?
I Have an aftermarket warranty. I know it wont cover shocks but will likely cover the compressor. Probably not the recalibration though. Thanks in advance for all advice. I'd like to save some money for Christmas lol
these seize solid misread, and will snap off in the end beeching the car - they are cheap budget ($40 dollar) parts that die any time around 5 to 8 year intervals
rear A 22 132 025 89
UK site
front https://www.ebay.co.uk/itm/125714842498?
rear https://www.ebay.co.uk/itm/111385921315?
if you are asking about them note:
1) nothing holds the car up other than air - you could lose a limb, or die
2) the front's are easy, BUT use a jack or ramp to support the car when playing with joke suspension
3) you won't be able to fit the rear, and won't know anyone else that will do it well in the 30mins its takes (and MIGHT charge you $1200 to half break it)
