2010 S550 Factory amp dead
Old Apr 7, 2024 | 04:12 PM
gal121's Avatar
2010 s500 4matic
I was wondering if I could replace the factory amp with something a little bit cheaper than the OEM one ? If so, what would you recommend for something in the $300-$400 price range. Sincerely appreciate anyone’s assistance. I also don’t want to have any of the control features lost, due to an after market amp. Thanks in advance peeps.
Old Apr 7, 2024 | 05:21 PM
BOTUS's Avatar
S500
check entire thread - u can it doesn't operate correctly - it might be possible to flash with merc software but the proponent's of this budget fix haven't even tried
https://mbworld.org/forums/s-class-w...ml#post8403150
Old Apr 20, 2024 | 12:12 PM
ZedbenzoS550's Avatar
S550
A 2011-2013 Honda Equus Amplifier will work ($73 INCLUDING shipping)...however, you have to shut the radio off to raise or lower the volume...OR $600 on ebay and take your chances...
Old Apr 21, 2024 | 05:16 AM
Jaap's Avatar
2006 W221 S500L M273
You mean Hyundai Equus?
They do look the same on the outside.
Do you have any references to the volume chaning problem?
Old Apr 21, 2024 | 05:28 AM
BOTUS's Avatar
S500
in the link from my post - loads have tried it - its a naff idea that doesn't work - loading the merc software might be genius
Old Apr 22, 2024 | 11:44 AM
S550
Correct, Hyundai Equus. I moved on to other issues once the sound came back. If you do get one and solve the volume issue post it here, it will be appreciated!
Old Jun 3, 2024 | 04:55 PM
houmem24's Avatar
2009 S450
I did the replacement...all god except the volume control. Solution: increase/decrease the volume, push the mute button two times and you are good.
For sure it is worth it price wise. you can also replace with the one from Hyundai Genesis.
Old Jun 3, 2024 | 08:13 PM
S550
I just tried the suggested volume fix…it worked great! Thanks!
