noise from the ABC pump and foaming power steering fluid
Link for video:
In the 2nd video you can see that the power steering reservoir is filled with white foam.
(Just to make sure) is the power steering circuit also filled with CHF11S, Przemo91?
Airmatic cars will not have the duo-pump.
Power steering foaming fluid will have to be air getting in via the return circuit or via the front seal on the pump. Any leaks in the return line to the pump?
I always used ZHM in power steering and ABC until the 222 car which uses a different fluid for MBC and electric power steering. :-(
There are no fluid leaks, the ABC pump has been regenerated, the only place it can discharge fluid is the power steering tank. I changed the cap as well
Like JohnLane said: "Power steering foaming fluid will have to be air getting in via the return circuit or via the front seal on the pump."
Steering to the limits can blow the seals out of most hydraulic power steering pumps. You will hear the pump make high pitch noise when in that zone of destruction. When I get into that over pressure zone, I immediately steer out enough to hear normal operation of pump. Seals internal could be damaged and sucking air internally into system causing the sudsing you describe.
Electric steering is immune to over pressure when steering the wheel full left/right. No hydraulics.
If the car is being driven like that, it will never be healed.
Johnny
Example, inside the reservoir, above the P/S pump fluid, is air head space at atmospheric pressure, accounting for thermal expansion of fluid. Somehow a component venting back to the head space is sucking air from there?
Is the correct P/S fluid, not contaminated with moisture being used?
Make sure it’s not Aunt Mildred’s sewing machine oil…
Best
Johnny
Have a new ABC pump but sometimes stil steering goes heavy and after a sprint the steering wheel shakes when trying to steer (not in straight posision), only when warm and shut down for 10 minutes and start again it moans for a few seconds.
No idea whats going on but replacing the reservoir is the firts thing to do.
