How would I upgrade 2007 s550 Brake calipers
Old Jun 10, 2024 | 10:16 AM
bayou340's Avatar
2007 Mercedes s550
I would like to upgrade my rear brake calipers. I am OK with the front ones because they are the larger sized Brembo brakes (Mercedes OEM without insignia) but wouldn't be opposed to upgrading the front and rears. Does anyone know if any of the other Mercedes model brake calipers will fit my car? Maybe the s600 rear brake calipers will fit the s550? I like the look of the larger rear brakes. I was thinking some of the AMG models might fit. I've read thru a few of the threads but most of the information was confusing. I figured it would just be easier to create a new thread. Thanks in advance for any assistance you can provide.
Old Jun 10, 2024 | 10:46 AM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
So the S65 uses larger AMG brake calipers with dual calipers at the front. The S600 uses single Brembo calipers at the front with vented disc rotors. If you are seeking upgraded brake performance, I would swap the pads for Hawk yellow ceramic front and rear (I found them not at Hawk but at Tirerack.com!) and upgrade to Brembo vented rotors. Much improved braking.
I swapped for Hawk Pads and new Brembo vented rotors for my S600 and have been very happy.
I would not go for the S65 dual calipers and rotors due to the expense.
Old Jun 10, 2024 | 11:30 AM
bayou340's Avatar
2007 Mercedes s550
Thanks for responding. I am mainly interested in the style. I have the vented disc rotors on front and rear. Just mainly concerned with rear calipers. I want a larger rear caliper.
Old Jun 10, 2024 | 12:23 PM
Jaap's Avatar
2006 W221 S500L M273
The brakes front vs. rear are "balanced" in that when you press the brake pedal, a certain percentage of the brake force goes to the front vs the rear, say 70% : 30%.
If you only upgrade the rear, it might become 65 : 35 and braking hard while cornering may give you oversteer etc.
So the general advice is to upgrade both front and rear.
Old Jun 10, 2024 | 01:42 PM
bayou340's Avatar
2007 Mercedes s550
Never thought of that. Thanks for the input!
Old Jun 11, 2024 | 08:34 AM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
If it is just the "look" you want, then do what you want... If you actually want the car to stop better, then upgrade the front and rear pads to something that will actually stop the car better.. then you will feel way better about doing something positive to the car and yourself.
Old Jun 11, 2024 | 08:41 AM
bayou340's Avatar
2007 Mercedes s550
The pads are not the issue, which is why I didn't mention them. The front caliper is not the issue because I stated this in my initial post. I simply want a larger rear caliper, which is why I was asking if anyone knew of any other Mercedes models in which the rear caliper will fit my s550. But thanks for your input anyway.
Old Jun 11, 2024 | 08:47 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
As others have said...."could" throw off the "balance"...but, the reality is the brakes in the front are larger due to physics, nothing more, nothing less. You can put a GIANT rear rotor on the car, assuming it fits within the confines of the wheel and does not have a massively larger pad area...it has the same (percentage) of stopping power due to the transfer of mass/kinetic energy to the contact patches (pad-rotor/tire-road). I mean, seriously, worst case is the rear tires enact an ABS thing - and I doubt that.
Old Jun 11, 2024 | 08:50 AM
bayou340's Avatar
2007 Mercedes s550
Thanks for your response.
Old Jun 11, 2024 | 09:36 AM
doni01's Avatar
2013 S550 4MATIC
I agree, pads have none to do with what you are asking! Below is what you need
https://mbworld.org/forums/s-class-w...-calipers.html
Old Jun 11, 2024 | 10:11 AM
bayou340's Avatar
2007 Mercedes s550
Yeah, I came across this thread :-) Since I only want to switch the rear calipers, I am conducting research to see if the an S600 rear calipers will fit my s550. Thanks for your response.
Old Jun 11, 2024 | 04:05 PM
221-423-04-81-64 is the (right) rear caliper on the 550. ($251)
221-423-04-81-64 - is the (right) rear caliper on the 600 ($251)....
So, they are the same calipers....its a popular caliper
2018 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2017 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2016 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2015 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2014 Mercedes-Benz CL 550 4Matic® 4.7L V8 - Gas 2014 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2014 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2014 Mercedes-Benz E 550 4Matic® 4.7L V8 - Gas 2013 Mercedes-Benz CL 550 4Matic® 4.7L V8 - Gas 2013 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2013 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2013 Mercedes-Benz E 550 4Matic®, Base 4.7L V8 - Gas 2013 Mercedes-Benz S 350 Bluetec 4Matic® 3.0L V6 - Diesel 2013 Mercedes-Benz S 400 Hybrid 3.5L V6 - Electric/Gas, 3.5L V6 - FULL HYBRID EV-GAS (FHEV) 2013 Mercedes-Benz S 550 4Matic®, Base 4.7L V8 - Gas 2013 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2012 Mercedes-Benz CL 550 4Matic® 4.7L V8 - Gas 2012 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2012 Mercedes-Benz CLS 550 4Matic®, Base 4.7L V8 - Gas 2012 Mercedes-Benz E 550 4Matic® 4.7L V8 - Gas 2012 Mercedes-Benz S 350 Bluetec 4Matic® 3.0L V6 - Diesel 2012 Mercedes-Benz S 400 Hybrid 3.5L V6 - Electric/Gas, 3.5L V6 - FULL HYBRID EV-GAS (FHEV) 2012 Mercedes-Benz S 550 4Matic®, Base 4.7L V8 - Gas 2012 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2012 Mercedes-Benz SL 550 Base 5.5L V8 - Gas 2011 Mercedes-Benz CL 550 4Matic® 4.7L V8 - Gas 2011 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2011 Mercedes-Benz E 550 4Matic®, Base 5.5L V8 - Gas 2011 Mercedes-Benz S 400 Hybrid 3.5L V6 - Electric/Gas, 3.5L V6 - FULL HYBRID EV-GAS (FHEV) 2011 Mercedes-Benz S 550 4Matic®, Base 5.5L V8 - Gas 2011 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2011 Mercedes-Benz SL 550 Base 5.5L V8 - Gas 2010 Mercedes-Benz CL 550 4Matic® 5.5L V8 - Gas 2010 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2010 Mercedes-Benz E 550 4Matic®, Base 5.5L V8 - Gas 2010 Mercedes-Benz S 400 Hybrid 3.5L V6 - Electric/Gas, 3.5L V6 - FULL HYBRID EV-GAS (FHEV) 2010 Mercedes-Benz S 550 4Matic®, Base 5.5L V8 - Gas 2010 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2009 Mercedes-Benz CL 550 4Matic® 5.5L V8 - Gas 2009 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2009 Mercedes-Benz S 550 4Matic®, Base 5.5L V8 - Gas 2009 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2009 Mercedes-Benz SL 550 Base 5.5L V8 - Gas 2008 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2008 Mercedes-Benz S 550 4Matic®, Base 5.5L V8 - Gas 2008 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2008 Mercedes-Benz SL 550 Base 5.5L V8 - Gas 2007 Mercedes-Benz CL 600 Base 5.5L V12 - Gas 2007 Mercedes-Benz S 550 4Matic®, Base 5.5L V8 - Gas 2007 Mercedes-Benz S 600 Base 5.5L V12 - Gas 2007 Mercedes-Benz SL 550 Base 5.5L V8 - Gas
