Water coming out of center console
Old Jul 16, 2024 | 09:01 PM
xx2pro4uxx21's Avatar
2009 S600
It's as it says. I was running the car to see if it would keep a constant temperature. First thing I noticed was water spraying out of the windshield washer cap which I learned was the heater so I know that. So I started it again and ran it for about 10 minutes. It didn't overheat but first I noticed steam coming out of the rear vents. I noticed the temperature was turned to high and it was on so I turned it off and it stopped. A couple minutes later I noticed steam coming from the center console near the dial for the screen (I have a 2009 s600) and then water came out. Is another heater broken?
Old Jul 17, 2024 | 03:43 AM
BOTUS's Avatar
S500
three possible sources...
1) rain water - the screen drains are a joke and detritus also builds under the battery, then leaks in destroying the heater blower motor
2) AC condense not draining out on tot the floor beneath the car via the drain pipes from the bottom of the HVAC system sitting behind the dash
3) the Heater matrix or its pipes - inside the HVAC system is a baby radiator which is part of the engine cooling system - if this leaks at a pipe connector or the unit fails engine coolant will be pumped in tot he car and ruin everything - normally owners notice the hideous pungent smell and fix before its bad
from the sounds of it it engine coolant - if so it will have a distinct taste and smell and dry making a mess - the windscreen washer bottle has a stupid heater system that pumps engine coolant around to melt ice in the winter (every other manufacturer just tells the owner to put the correct concentration of washer fluid to keep the whole system working properly - not just melt ice 1" from the tubes after a 10 mile journey
good luck with any electrics ever working well again
Old Jul 17, 2024 | 04:00 AM
benzuserjee's Avatar
A 200 Sedan
oof, water and electronics don't mix. good luck with the repairs.
Old Jul 17, 2024 | 10:32 AM
2009 S600
Ok I didn't think about that first one. I hope that's all it is lol. Probably isn't the second one because I know for a fact that there's no ac refrigerant in the system. So it can't get cold enough to cause condensation. number 3 is what I was thinking it could be. But I'm not sure what the part number is for the heater core. Don't want to buy the wrong part lol.
Old Jul 17, 2024 | 11:49 AM
2009 S600
I was thinking. Since it was steaming, wouldn't it have to come from the engine cooling system. Does anyone know if any of the heater cores or anything else for that matter, comes close to HVAC tubing? specifically the ones for the rear since it wasn't happening in the front. And specifically the vents that are under the front seats for the rear passengers. Then for the center console, do the tubes for the rear climate vents that come out of the middle run under there?
Old Jul 17, 2024 | 12:03 PM
BOTUS's Avatar
S500
you could try and track the pathway for the stupid washer bottle heater.... unless those heater pipes come from the interior heater system somehow - I don't see how that extra bit of fun is part of the issue.... (but very unlikely to be a coincidence) unless !!!! we have a real catastrophic failure on our hands and you have combustion gases leaking out at such a rate its popped the screen washer heater pipes and the heater matrix core in one nasty mess...
this is a pic I coloured in of a V8 heater system...
you could double check and try and work out which for the v12 here...
https://nemigaparts.com/cat_spares/e...221176/63v/83/
Old Jul 17, 2024 | 01:30 PM
2009 S600
If it did happen to break both of those, would possibly cause that?
Old Jul 17, 2024 | 03:18 PM
2009 S600
Alright cool those diagrams help alot. This is what I see in one of them.
Where I saw the steam coming from and the vents that go under the center console are connected. If that is a hole in the top of the vents under the center console then it could be leaking water somehow into those tubes. Yet to be determined on that one.
Old Jul 17, 2024 | 04:11 PM
BOTUS's Avatar
S500
taste the water if its sweet its likely got antifreeze....
mind u not sure on the later stuff
Old Jul 17, 2024 | 07:31 PM
2009 S600
Yes it does.
Old Jul 22, 2024 | 06:05 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
i got bad news, probably the heater core. Which is inside the dash, it's gonna be an extensive repair
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jul 22, 2024 | 05:48 PM
Senecat's Avatar
1983 Nissan Shltbox
Isn't there another evap coil/heat exchanger in the center console for the rear zone in cars with the dual zone option?
Old Jul 23, 2024 | 05:20 AM
BOTUS's Avatar
S500
for cars with optional rear heater buttons - those bits sit in the centre console... where a second AC evaporator, another heater matrix and separate blower motor is hiding.... with their heater valve (that goes wrong) in the wing behind the right front wheel (on my RHD car)
Old Jul 23, 2024 | 05:24 AM
BOTUS's Avatar
S500
water coming out the rear vents doesn't seem to explain the engine coolant spraying out the top of the windscreen washer bottle !!!!
I'm worried the engine has gone bang ! and its the massive pressure spike that has popped the rads / heater matrix
Old Jul 23, 2024 | 04:51 PM
Senecat's Avatar
1983 Nissan Shltbox
It appears there may be multiple issues at hand.
Old Jul 23, 2024 | 06:40 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
I agree. This sounds like a bad head gasket. He should check for hydrocarbons in the coolant.
